Results 1 to 17 of 17
  1. I want help downloading from videos and movies from Dittotv
    for example ,this video : http://www.dittotv.com/tvshows/dil-dosti-duniyadaari
    the website while streaming downloads several parts each nearly 8-9 s long and when i download one of it ,it can be played by VLC and has extension *.ts
    I can download the full video using ffmpeg by locating the m3u8 file but ffmpeg downloads one packet at a time and the time taken to download the full video is nearly equal to the duration of the video .
    i am looking for a better option to ffmpeg which can download the video in multiple threads like IDM
    p.s. replay media catcher 5 dosent work
    Last edited by johns0; 30th Oct 2015 at 17:59. Reason: Setting fonts to normal size
  2. use normal text so peeps can read it
    tools
    firefox addon
    adblock plus
    and
    livestreamer
    open blockable items
    search for
    master.m3u8
    copy url
    livestreamer "hlsvariant://http://zeeapp4-vh.akamaihd.net/i/draco//shows/Zee_Marathi/Dil_Dosti_Duniyadaari/October/30102015/Dil_Dosti_Duniyadaari_Episode_202.smil/master.m3u8?key1=dittotv.com&hdnea=st=1446234961~exp=1446236461~acl=*~hmac=436b575255382d3b5fa3da88498210cfe8bea5690d38cd5831fc4c6ffa607381" best -o crap.ts
  3. Originally Posted by bobit View Post
    You can read it. I can read it. I'm sure others can too...
  4. read this
    shut up mug
    posting txt like a colouring book
    in forums is $hit to read
    pity you didn't pipe in and sort the downloading of the op's stream out
    instead of posting $hit for the sake of it
  5. your method worked . thanks bobbit
    and i didnt colour the text . the coloured text are hyperlinks. sry for that
    Jan 2015
    India
    Not exactly the answer you are looking for but i can download the videos of show you posted using IDM. But for that you will need to find which channel it belongs. The show you posted belongs to zee marathi and i opened the show page on zee marathi website and not on the ditto tv website.
    http://www.zeemarathi.com/shows/dil-dosti-duniyadaari
    When this page opens follow the steps.
    Press
    Ctrl+u in the video page to view source.
    Ctrl+f to Look for pmd
    You will find a link like
    http://pmd.dittotv3.com.edgesuite.net/draco/shows/Zee_Marathi/Dil_Dosti_Duniyadaari/October/30102015/Dil_Dosti_Duniyadaari_Episode_30102015_100.mp4?key1=www.zeemarathi.com&hdnea=st=1446268562~exp=1446270062~acl=%2F%2A~hmac=e0709342c2a312306f6717ac65dd07969f7c15099bbb24ddf21257c6f3cee866
    Just change the part in blue to 864 and use IDM.
    But there is one drawback. The link expires from time to time so you need to keep refreshing the links by this method repeatedly if the video is long.
    P.S. This method does not work for zee tv soaps but works for other channels.
  7. the method described by sscomp32 is better when i want to download the tv soaps but the method by bobit is helpful when i have to download movies from ditto tv.
    Thanks for the help guys!
    Jan 2015
    India
    Ok i am in a fix now. I need a show which is not uploaded by the channel and only by ditto tv.
    Can anybody get the direct mp4 link
    http://www.dittotv.com/tvshows/bad-company/episodes/bad-company-season-1-warrior-high-...-uncut-episode
    The source is encrypted unlike other shows.
    I know i can use the livestreamer method but i want to download the direct mp4 using IDM.
    Thanks in advance.
  9. Originally Posted by sscomp32 View Post
    Thanks in advance.
    i used livestreamer to get it
    took 2mins 48secs
    tools
    firefox addon
    adblock plus
    and
    livestreamer
    search for
    flv
    copy url
    delete http://
    replace with
    livestreamer "hlsvariant://zeeapp4-vh.akamaihd.net/i/draco/shows/Zing_TV/Bad_Company/November/BC-Export-E02-Warrior-High-Cast/Warrior-High-Cast.smil/master.m3u8?key1=dittotv.com&hdnea=st=1446895000~exp=1446896500~acl=*~hmac=cd7968c5ae7b138e54fc5f6700222f86cfef1936b056baa9812df85b4ae19d1f" best -o Bad_Company.mp4
  10. Originally Posted by bobit View Post
    tools
    firefox addon
    adblock plus
    and
    livestreamer
    search for
    master.m3u8
    copy url
    I did all these as instructed.....but once I give in in the cmd box....the part in Red does not come for me...
    Instead I get
    What should I do?
  11. Originally Posted by Here4Help View Post
    It only took me a minute to download the 640x360, 100 MB, 21 minute episode with ffmpeg, using the m3u8 link. 1/20 the running time of the video.
    Jan 2015
    India
    @bobit: i think you didn't read my question.
    I know livestreamer method but want the other method. Like i mentioned in post #6.
    Cant used the same tricks because source code is encrypted.
    I want a link downloadable through IDM with resume support.
    Ofcourse if nothing works then i would have to go back to the livestreamer method.
  13. i just installed IDM just for you lol
    and got that file like this
    tools
    firefox addon
    httpfox
    and
    IDM
    start your stream and httpfox
    search for
    master
    put mouse on link
    IDM
    will now pop up and say download this
    download the quality of video you want
    rename .ts to .mp4
    before you ok the download
    now i will delete this IDM
    i like cmd prompt or a Terminal
  14. Originally Posted by divapinky View Post
    What should I do?
    @divapinky
    you did not put what format you wanted or where on your pc it was to be saved and what name it will be saved as
    and what extension
    so
    it is telling you what formats there are
    put this at the end
    " best -o crap.ts
    including that quote
  15. HI all,
    I am trying to download videos from &TV using the method suggested by you guys. But it's not working. Can you please help me with it.
    Video URL:http://www.andtv.com/shows/bhabi-ji-ghar-par-hai/video/bhabi-ji-ghar-par-hain-episode-...l-episode.html
    Feb 2016
    Mysore India
    Hello, this is my 1st post in this forum. I landed in this page by googling how to download videos from dittotv and I was happy to see the post.
    I have one issue. I want to download the video from the page:
    http://www.dittotv.com/tvshows/parambariya-maruthuvam/episodes/paarambariya-maruthuvam...6-full-episode
    But the video is not at all loading. I am in a college where the internet browsing is through a firewall called 'Cyberoam'. I can view the page but the video always shows loading/streaming symbol for a long time (attached screenshot). I don't know where the problem is. I have latest firefox/chrome/flash player etc.
    Please help
