Hello. I have an nvidia 750Ti video card which is apparently VP6.
Is there a commandline program for using Nvidia's GPU encoder NVEnc, which accepts avisynth 2.5.7 input ?
I did see NVEncC 1.11
https://forum.videohelp.com/threads/370223-NVEncC-by-rigaya-NVIDIA-GPU-encoding?p=2415883&viewfull=1
however that seems as if it may have japanese scattered through instructions etc and I'm not sure how to feed it avisynth 2.5.7.
My goal is to produce mainly h264 in an mp4 container (i currently use x264.exe), but would also like to start playing with h265 as well.
(I do have avs2yuv.exe to feed into 64 bit x264, but that's it).
Results 1 to 29 of 29
Are you looking for a GUI ? I think staxrip and hybrid can use them
NVEncC accepts avs scripts directly , if you use the matching version (ie. 32bit avisynth with NVEncC , or 64bit avisynth with NVEncC64) , or you can pipe to NVEncC with various methods
But it only outputs raw AVC, no container . So you'd have to use something else like mp4box as well, or one of the GUI's
eg. 1pass vbr 2000kb/s
(BTW, VP6 or VPx in terms of Pure Video for Nvidia is only for DEcoding - it's not the part does the ENcoding)Code:NVEncC.exe --avs -i input.avs --vbr 2000 -o output.264
My workflow is largely automated and commandline driven.
Fantastic !
Good oh. I suppose could use ffmpeg to mux the video whilst converting the audio at the same time, or use ffmpeg to convert the audio and mp4box to mux those separate streams.
OK, I generally use --crf 16 to --crf 24 with x264.exe, so I'll have to find the equivalent switches for NVEncC ... and then the same for h.265Code:NVEncC.exe --avs -i input.avs --vbr 2000 -o output.264
Ah, thank you.
https://en.wikipedia.org/wiki/Nvidia_PureVideohttps://en.wikipedia.org/wiki/Nvidia_NVENCPureVideo (eg VP6) occupies a considerable amount of a GPU's die surface and should not to be confused with Nvidia NVENC.Nvidia NVENC is the name given to Nvidia's ASIC IP block that performs video encoding. It was introduced with the Kepler-based GeForce 600 series in March 2012, as a product feature that offloads H264 video encoding from the host CPU.
Any other commandline nvenc encoders available ? -
I see https://en.wikipedia.org/wiki/Nvidia_NVENC
Which would be really fantastic ... however I don't reckon zeranoe's windows build http://ffmpeg.zeranoe.com/builds/ has it enabledFFmpeg obtained support to use Nvidia NVENC in 2014.
I would ask at zeranoe's forum to see if anyone has got it working for ffmpeg
Also look at the NVEnc help - because the switches are going to be basically the same. They might be named slightly differently due to ffmpeg syntax and formatting
It doesn't have a CRF mode or even something similar. Only the 3 listed above. CQP is like QP for x264 - constant quantizer encoding. Not very efficient. In my tests, NVEnc is fast, but you're going to be disappointed in the quality/compression coming from x264Code:--cqp <int> or encode in Constant QP mode <int>:<int>:<int> Default: <I>:<P>:<B>=<20>:<23>:<25> --vbr <int> set bitrate for VBR mode (kbps) --cbr <int> set bitrate for CBR mode (kbps) Default: 7500 kbps --max-bitrate <int> set Max Bitrate (kbps) / Default: 17500 kbps -
-h full , for the full help. -h gives the short version
I saw that someone offered to build it for you on zeranoe's forum if you PM him... take him up on the offer -
I very nearly did. Didn't though.
https://www.ffmpeg.org/doxygen/2.7/nvenc_8c_source.html
Why did erase all the posts ??
I was playing around with it and was going to say the quality is very poor (even worse than the NVEncC version) . But looking closer - the main reason is because the default HQ preset has zero b-frames, tiny max keyframe interval . If you set the settings similar to NVEncC , the results are closer but still some differences. I have to look a bit closer when I have time to see why there are still differences;
Very fast, but the compression is still quite poor . I was looking at the marketing slides and maxwell 2 cards are supposed to be 80% faster than maxwell 1 for NVEnc. A typical 1280x720p encode gets about 400-500 FPS on Maxwell 1 (900-1000FPS for SD) . maxwell 2 is probably decoding limited for AVC SD sources (you can get ~1000FPS-1100FPS decoding with GPU decoding)
(I built it with an autobuild script , there are 2 commonly used ones. At first I tried building it in Windows, it was a huge waste of time. Neither worked after 6+ hours each ! In linux it takes about 2 hours using the rdp version)
https://github.com/jb-alvarado/media-autobuild_suite
https://github.com/rdp/ffmpeg-windows-build-helpersLast edited by poisondeathray; 3rd Nov 2015 at 16:20.
What details did you want specifically ?
Yes, I mean "typical" encode with I,P, 3 max b-frames for AVC . The speeds are similar (as expected) between NVEncC and the ffmpeg variant of NVEnc when using similar settings. I only tested SD and HD sources so far (no UHD), and only AVC encoding. You can run 2 simultaneous encodes if your GPU isn't at 100% (e.g. there is some bottleneck to feeding NVEnC, like resizing, filtering etc..). The FPS is almost additive with slight overhead (apparently 2 instances is the limit per GPU, but I didn't test more than 2). I didn't test HEVC encoding which is available on maxwell 2, but from another poster, it looks like HEVC encoding is as fast as AVC encoding on NVEnc (!), but has no b-frames -
An apparent lack of support for interlaced encoding may make nvenc a waste of time.
(I couldn't get it to work, the output was shuddery).
The extra time taken to deinterlace TV capture material before encoding as progressive brings the effective end-to-end throughput speed right back to the field. It unfortunately also eliminates retention of "motion fluidity" for fast sports action given by interlacing.
Does anyone know if ffmpeg has an nvidia GPU deinterlacer similar or better than yadif above ?REM 25 fps
".\ffmpeg.exe" -i "inp.mpg" -filter:v yadif=0:0:0,setdar=dar=16/9,unsharp -r 25 -c:v nvenc -preset hq -b:v 1900k -minrate 500k -maxrate 5000k -profile:v high -level 4.1 -coder 0 -bf 3 -g 50 -movflags +faststart -c:a libmp3lame -ab 265k -ar 44100 -y "out.mp4"
REM 50 fps
".\ffmpeg.exe" -i "inp.mpg" -filter:v yadif=1:0:0,setdar=dar=16/9,unsharp -r 50 -c:v nvenc -preset hq -b:v 3800k -minrate 500k -maxrate 5000k -profile:v high -level 4.1 -coder 0 -bf 3 -g 50 -movflags +faststart -c:a libmp3lame -ab 265k -ar 44100 -y "out.mp4"
PS what ffmpeg switches can you use to pass to nvenc to achieve get I,P, 3 max b-frames ?Last edited by hydra3333; 27th Nov 2015 at 20:06. Reason: edit: added "-bf 3 -g 50"
nvencc supports interlaced encoding
I'll take a closer look, but ffmpeg's nvenc should too thenH.264/AVC
--interlaced <string> interlaced encoding
tff, bff
Nvidia does have a GPU deinterlacer, but it's on the DEcoding portion (PureVideo) , not the NVEnc encoding portion. I don' t think you can access it through ffmpeg. You can access it through an avs script if you have DGDecNV. Quality isn't that great, it's similar to yadifDoes anyone know if ffmpeg has an nvidia GPU deinterlacer similar or better than yadif above ?
-bf 3 => max 3 b-framesPS what ffmpeg switches can you use to pass to nvenc to achieve get I,P, 3 max b-frames ?
-g => max GOP size. I don't know what is "ideal" for NVEnc, but it's 250 for x264 default. It was something like 12 at default for ffmpeg NVEnc, very poor efficiency -
Thank you.
Yes; oh well I'd hoped there was a GPU deinterlacer accessible from within ffmpeg.
AVS isn't a goer for me. I tried, thinking "you beaut, GPU mpeg2 hardware decoding/deinterlacing and GPU h.264 hardware encoding", but for various reasons I am wedded to an old avisynth v2.57 which the newer ffmpeg build refuses to use directly (byo build of ffmpeg requires v2.6 or greater).
I suppose I could try avs2yuv with an AVS vs script, for PAL-SD GPU mpeg2 hardware decoding/deinterlacing feeding ffmpeg's NVEnc, sort of like
Not sure about effects of large bus transfers left right and centerCode:".\avs2yuv.exe" "script.avs" -o - | ".\ffmpeg.exe" - --stdin y4m --thread-input --threads 8 -filter:v setdar=dar=16/9,unsharp -r 25 -c:v nvenc -preset hq -b:v 1900k -minrate 500k -maxrate 5000k -profile:v high -level 4.1 -coder 0 -bf 3 -g 50 ... etc
but then it'd still be not much use to for me for the files which I need to keep as interlaced since you pointed out ffmpeg's nvenc doesn't do interlaced ...
Thanks. I wonder, does ffmpeg's nvenc takes any notice of the settings ?PS what ffmpeg switches can you use to pass to nvenc to achieve get I,P, 3 max b-frames ?
I also wonder if it could be possible for an ffmpeg developer to port relevant NVEncC code to "transfer" the interlaced settings and whatnot into ffmpeg for nvenc without breaking any licensing ?
For posterity, an ubuntu based fmfpeg.exe-for-windows build script is here https://github.com/rdp/ffmpeg-windows-build-helpers
Build like
Noting -march obtained via https://wiki.gentoo.org/wiki/GCC_optimization and https://gcc.gnu.org/onlinedocs/gcc/x86-Options.htmlCode:sudo ./cross_compile_ffmpeg.sh --gcc-cpu-count=2 --build-ffmpeg-shared=n --build-ffmpeg-static=y --disable-nonfree=n --build-libmxf=n --build-mp4box=n --build-mplayer=n --build-vlc=n --git-get-latest=y --prefer-stable=n --high-bitdepth=n --compiler-flavors=win32 --cflags="-march=sandybridge"
Yes, ffmpeg's nvenc uses -bf and -g. The quality difference is huge. That' s the first thing I noticed - why is the quality so poor compared to NVEncC (which already isn't that great compared to x264) so I looked closer at the bitstream - That's the main reason, no b-frames, short keyframe interval. In typical bitrate ranges you're already >50% worse off in terms of compression.
The ffmpeg nvenc code has provisions for interlaced encoding , and the output is flagged correctly
But there are big problems with it, quality wise. Something isn't implemented correctly because it works in NVEncC -
FFmpeg supports HW decoders through -hwaccel , but in reality it's not useful - at least not on windows. In my tests , the speed is the same or slower at least for dxva2. Selur had similar experience noted in this thread
http://forum.doom9.org/showthread.php?t=170793
VDPAU for NVidia is supported in FFmpeg, but only in linux. It supports deinterlacing
https://trac.ffmpeg.org/wiki/HWAccelIntro
http://http.download.nvidia.com/XFree86/vdpau/doxygen/html/index.html
If you have quicksync, qsv can be used to decode and encode. I haven't gotten around to testing the ffmpeg implementation yet. (If you have quicksync, you probably wouldn't use NVEnc, it's slower but the quality is much better at least on haswell or newer) -
Still looking to
- deinterlace using ffmpeg with an NVidia card
- and, encode interlaced with ffmpeg with an NVidia card
I receive an ffmpeg error trying to use -hwaccel with mpeg2 input (win10, latest nvidia drivers, 750Ti nvidia card).
May I enquire on your commandline ? -
You could keep an eye open at Rigaya's website for the NVEnc updates.
https://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=search&rurl=tra...aAGrEsv8UAXQDA
Then, pass your mouse over the download link just below the heading on that page for the latest version.
use { NVEnc --check-features } for what your current cpu is capable of. Then run your battery of trial and error tests encodes.
I think that these hardware encoders follow the same encoding limitations. They seem to do better on 1920x1080 pixels. Lower resolution tends to produce poor quality no matter what settings used. These encoders want clean video. Anything with compression artifacts will produce poor results once encoded by these encoders. Well, that's been my experience with QSVenc, which is from same developer, by the way. In my personal opinion, I think that Intel's Quick Sync hardware encoder produces the best quality, but then again, no one is posting actual samples (commercial movies) from NVidia and AMD devices for me to gauge from. So, I gotta believe that qs is the best so far. -
Referenced here as a "more genuine" NVEncC thread.
A fair bit of water has gone under this bridge
NVEncC can input vapoursynth .py files.
Great ! It means I can use DG's fantastic gpu enabled software filters in vapoursynth ... now I'm not sure how to also pass audio through the vapoursynth chain ...
As a side note:
NVEncC also offers lots of video post processing filters from the vpu chip.
-> check the '--vpp-.. options.
Code:NVEncC (x64) 4.29 (r977) by rigaya, Dec 17 2018 12:04:34 (VC 1900/Win/avx2) [NVENC API v8.1, CUDA 8.0] reader: raw, avi, avs, vpy, avhw [H.264/AVC, H.265/HEVC, MPEG2, VP8, VP9, VC-1, MPEG1, MPEG4] Usage: NVEncC.exe [Options] -i <input file> -o <output file> Input can be avi, avs, raw YUV, YUV4MPEG2(y4m). When Input is in raw format, fps, input-res is required. Ouput format will be in raw H.264/AVC or H.265/HEVC ES. Example: NVEncC -i "<avsfilename>" -o "<outfilename>" avs2pipemod -y4mp "<avsfile>" | NVEncC --y4m -i - -o "<outfilename>" Information Options: -h,-? --help print help -v,--version print version info --check-device show DeviceId for GPUs available on system --check-hw [<int>] check NVEnc codecs for specified DeviceId if unset, will check DeviceId #0 --check-features [<int>] check for NVEnc Features for specified DeviceId if unset, will check DeviceId #0 --check-environment check for Environment Info --check-avversion show dll version --check-codecs show codecs available --check-encoders show audio encoders available --check-decoders show audio decoders available --check-profiles <string> show profile names available for specified codec --check-formats show in/out formats available --check-protocols show in/out protocols available --check-filters show filters available Basic Encoding Options: -d,--device <int> set DeviceId used in NVEnc (default:-1 as auto) use --check-device to show device ids. -i,--input <filename> set input filename -o,--output <filename> set output filename Input formats (auto detected from extension of not set) --raw set input as raw format --y4m set input as y4m format --avi set input as avi format --avs set input as avs format --vpy set input as vpy format --vpy-mt set input as vpy(mt) format --avhw [<string>] use libavformat + cuvid for input this enables full hw transcode and resize. avhw mode could be set as a option - native (default) - cuda --avsw set input to use avcodec + sw decoder --input-analyze <int> set time (sec) which reader analyze input file. default: 5 (seconds). could be only used with avhw/avsw reader. use if reader fails to detect audio stream. --video-track <int> set video track to encode in track id 1 (default) highest resolution video track 2 next high resolution video track ... -1 lowest resolution video track -2 next low resolution video track ... --video-streamid <int> set video track to encode in stream id --audio-source <string> input extra audio file --audio-file [<int>?][<string>:]<string> extract audio into file. could be only used with avhw/avsw reader. below are optional, in [<int>?], specify track number to extract. in [<string>?], specify output format. --trim <int>:<int>[,<int>:<int>]... trim video for the frame range specified. frame range should not overwrap each other. --seek [<int>:][<int>:]<int>[.<int>] (hh:mm:ss.ms) skip video for the time specified, seek will be inaccurate but fast. --input-format <string> set input format of input file. this requires use of avhw/avsw reader. -f,--output-format <string> set output format of output file. if format is not specified, output format will be guessed from output file extension. set "raw" for H.264/ES output. --audio-copy [<int>[,...]] mux audio with video during output. could be only used with avhw/avsw reader and avcodec muxer. by default copies all audio tracks. "--audio-copy 1,2" will extract audio track #1 and #2. --audio-codec [<int>?]<string> encode audio to specified format. in [<int>?], specify track number to encode. --audio-profile [<int>?]<string> specify audio profile. in [<int>?], specify track number to apply. --audio-bitrate [<int>?]<int> set encode bitrate for audio (kbps). in [<int>?], specify track number of audio. --audio-ignore-decode-error <int> (default: 10) set numbers of continuous packets of audio decode error to ignore, replaced by silence. --audio-samplerate [<int>?]<int> set sampling rate for audio (Hz). in [<int>?], specify track number of audio. --audio-resampler <string> set audio resampler. swr (swresampler: default), soxr (libsoxr) --audio-stream [<int>?][<string1>][:<string2>][,[<string1>][:<string2>]][.. set audio streams in channels. in [<int>?], specify track number to split. in <string1>, set input channels to use from source stream. if unset, all input channels will be used. in <string2>, set output channels to mix. if unset, all input channels will be copied without mixing. example1: --audio-stream FL,FR splitting dual mono audio to each stream. example2: --audio-stream :stereo mixing input channels to stereo. example3: --audio-stream 5.1,5.1:stereo keeping 5.1ch audio and also adding downmixed stereo stream. usable symbols mono = FC stereo = FL + FR 2.1 = FL + FR + LFE 3.0 = FL + FR + FC 3.0(back) = FL + FR + BC 3.1 = FL + FR + FC + LFE 4.0 = FL + FR + FC + BC quad = FL + FR + BL + BR quad(side) = FL + FR + SL + SR 5.0 = FL + FR + FC + SL + SR 5.1 = FL + FR + FC + LFE + SL + SR 6.0 = FL + FR + FC + BC + SL + SR 6.0(front) = FL + FR + FLC + FRC + SL + SR hexagonal = FL + FR + FC + BL + BR + BC 6.1 = FL + FR + FC + LFE + BC + SL + SR 6.1(front) = FL + FR + LFE + FLC + FRC + SL + SR 7.0 = FL + FR + FC + BL + BR + SL + SR 7.0(front) = FL + FR + FC + FLC + FRC + SL + SR 7.1 = FL + FR + FC + LFE + BL + BR + SL + SR 7.1(wide) = FL + FR + FC + LFE + FLC + FRC + SL + SR --audio-filter [<int>?]<string> set audio filter. in [<int>?], specify track number of audio. --chapter-copy copy chapter to output file. --chapter <string> set chapter from file specified. --key-on-chapter set key frame on chapter. --sub-copy [<int>[,...]] copy subtitle to output file. these could be only used with avhw/avsw reader and avcodec muxer. below are optional, in [<int>?], specify track number to copy. --caption2ass [<string>] enable caption2ass during encode. !! This feature requires Caption.dll !! supported formats ... srt (default), ass --avsync <string> method for AV sync (default: cfr) cfr ... assume cfr forcecfr ... check timestamp and force cfr vfr ... honor source timestamp and enable vfr output. only available for avsw/avhw reader, and could not be used with --trim. -m,--mux-option <string1>:<string2> set muxer option name and value. these could be only used with avhw/avsw reader and avcodec muxer. --input-res <int>x<int> set input resolution --crop <int>,<int>,<int>,<int> crop pixels from left,top,right,bottom left crop is unavailable with avhw reader --output-res <int>x<int> set output resolution --fps <int>/<int> or <float> set framerate -c,--codec <string> set output codec h264 (or avc), h265 (or hevc) --profile <string> set codec profile H.264: baseline, main, high(default), high444 HEVC : main, main10, main444 --tier <string> set codec tier HEVC : main, high --lossless for lossless (YUV444 only) / default: off --level <string> set codec level - H.264: auto(default), 1, 1b, 1.1, 1.2, 1.3 2, 2.1, 2.2, 3, 3.1, 3.2, 4, 4.1, 4.2 5, 5.1, 5.2 - HEVC: auto(default), 1, 2, 2.1, 3, 3.1, 4 4.1, 5, 5.1, 5.2, 6, 6.1, 6.2 --output-depth <int> set output bit depth ( 8(default), 10 ) --sar <int>:<int> set Sample Aspect Ratio --dar <int>:<int> set Display Aspect Ratio --cqp <int> or encode in Constant QP mode <int>:<int>:<int> default: <I>:<P>:<B>=<20>:<23>:<25> --vbr <int> set bitrate for VBR mode (kbps) --vbrhq <int> set bitrate for VBR (High Quality) mode (kbps) --cbr <int> set bitrate for CBR mode (kbps) --cbrhq <int> set bitrate for CBR (High Quality) mode (kbps) default: 7500 kbps --preset <string> set encoder preset default, performance, quality --vbr-quality <float> target quality for VBR mode (0-51, 0=auto) --max-bitrate <int> set Max Bitrate (kbps) --qp-init <int> or set initial QP <int>:<int>:<int> default: auto --qp-max <int> or set max QP <int>:<int>:<int> default: unset --qp-min <int> or set min QP <int>:<int>:<int> default: unset --gop-len <int> set GOP Length / default: 0 frames (auto) --lookahead <int> enable lookahead and set lookahead depth (1-32) default: 16 frames --strict-gop avoid GOP len fluctuation --no-i-adapt disable adapt. I frame insertion --no-b-adapt disable adapt. B frame insertion for lookahead mode only, default: off -b,--bframes <int> set number of consecutive B frames default: H.264 - 3 frames, HEVC - 0 frames --ref <int> set Ref frames / default 3 frames --weightp enable weighted prediction for P frame --mv-precision <string> set MV Precision / default: auto auto, Q-pel (High Quality), half-pel, full-pel (Low Quality, not recommended) --slices <int> number of slices, default 0 (auto) --vbv-bufsize <int> set vbv buffer size (kbit) / default: auto --(no-)aq enable spatial adaptive quantization --aq-temporal [H264] enable temporal adaptive quantization --aq-strength <int> [H264] set aq strength (weak 1 - 15 strong) default: 0 = auto --bref-mode <string> [H264] set B frame reference mode - disabled (default) - each - middle --direct <string> [H264] set B Direct mode auto(default), none, spatial, temporal --(no-)adapt-transform [H264] set adaptive transform mode (default=auto) --cabac [H264] use CABAC --cavlc [H264] use CAVLC (no CABAC) --bluray [H264] for bluray / default: off --(no-)deblock [H264] enable(disable) deblock filter --cu-max <int> [HEVC] set max CU size --cu-min <int> [HEVC] set min CU size 8, 16, 32 are avaliable warning: it is not recommended to use --cu-max or --cu-min, leaving it auto will enhance video quality. --videoformat <string> undef, ntsc, component, pal, secam, mac default: undef --colormatrix <string> undef, auto, bt709, smpte170m, bt470bg smpte240m, YCgCo, fcc, GBR, bt2020nc bt2020c default: undef --colorprim <string> undef, auto, bt709, smpte170m, bt470m bt470bg, smpte240m, film, bt2020 default: undef --transfer <string> undef, auto, bt709, smpte170m, bt470m bt470bg, smpte240m, linear, log100, log316 iec61966-2-4, bt1361e, iec61966-2-1 bt2020-10, bt2020-12, smpte2084, smpte428 arib-srd-b67 default: undef --aud insert aud nal unit to ouput stream. --pic-struct insert pic-timing SEI with pic_struct. --chromaloc <int> set chroma location flag [ 0 ... 5 ] default: 0 = unspecified --fullrange set fullrange --max-cll <int>,<int> set MaxCLL and MaxFall in nits. e.g. "1000,300" --master-display <string> set Mastering display data. e.g. "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --interlace <string> set input as interlaced tff, bff --vpp-deinterlace <string> set deinterlace mode / default: none none, bob, adaptive (normal) available only with avhw reader --vpp-resize <string> default, nn, npp_linear, cubic, super lanczos, bilinear, spline36 default: default --vpp-gauss <int> disabled, 3, 5, 7 default: disabled --vpp-knn [<param1>=<value>][,<param2>=<value>][...] enable denoise filter by K-nearest neighbor. params radius=<int> radius of knn (default=3) strength=<float> strength of knn (default=0.08, 0.0-1.0) lerp=<float> balance of orig & blended pixel (default=0.20) lower value results strong denoise. th_lerp=<float> edge detect threshold (default=0.80, 0.0-1.0) higher value will preserve edge. --vpp-pmd [<param1>=<value>][,<param2>=<value>][...] enable denoise filter by pmd. params apply_count=<int> count to apply pmd denoise (default=2) strength=<float> strength of pmd (default=100.00, 0.0-100.0) threshold=<float> threshold of pmd (default=100.00, 0.0-255.0) lower value will preserve edge. --vpp-unsharp [<param1>=<value>][,<param2>=<value>][...] enable unsharp filter. params radius=<int> filter range for edge detection (default=3, 1-9) weight=<float> strength of filter (default=0.50, 0-10) threshold=<float> min brightness change to be sharpened (default=10.00, 0-255) --vpp-edgelevel [<param1>=<value>][,<param2>=<value>][...] edgelevel filter to enhance edge. params strength=<float> strength (default=0, -31 - 31) threshold=<float> threshold to ignore noise (default=20.0, 0-255) black=<float> allow edge to be darker on edge enhancement (default=0.0, 0-31) white=<float> allow edge to be brighter on edge enhancement (default=0.0, 0-31) --vpp-deband [<param1>=<value>][,<param2>=<value>][...] enable deband filter. params range=<int> range (default=15, 0-127) sample=<int> sample (default=1, 0-2) thre=<int> threshold for y, cb & cr thre_y=<int> threshold for y (default=15, 0-31) thre_cb=<int> threshold for cb (default=15, 0-31) thre_cr=<int> threshold for cr (default=15, 0-31) dither=<int> strength of dither for y, cb & cr dither_y=<int> strength of dither for y (default=15, 0-31) dither_c=<int> strength of dither for cb/cr (default=15, 0-31) seed=<int> rand seed (default=1234) blurfirst blurfirst (default=off) rand_each_frame generate rand for each frame (default=off) --vpp-afs [<param1>=<value>][,<param2>=<value>][...] enable auto field shift deinterlacer params preset=<string> default, triple, double, anime, cinema, min_afterimg, 24fps, 24fps_sd, 30fps ini=<string> read setting from ini file specified (output of afs.auf) !! params from preset & ini will be overrided by user settings below !! Aviutl???????? top=<int> (?) clip range to scan (default=16) bottom=<int> (?) clip range to scan (default=16) left=<int> (?) clip range to scan (default=32) right=<int> (?) clip range to scan (default=32) left & right must be muitiple of 4 method_switch=<int> (???) (default=0, 0-256) coeff_shift=<int> (???) (default=192, 0-256) thre_shift=<int> (?(???)) stripe(shift)thres (default=128, 0-1024) thre_deint=<int> (?(??)) stripe(deint)thres (default=48, 0-1024) thre_motion_y=<int> (Y??) Y motion threshold (default=112, 0-1024) thre_motion_c=<int> (C??) C motion threshold (default=224, 0-1024) level=<int> (??Lv) set deint level (default=3, 0-4 shift=<bool> (????????) enable field shift (default=on) drop=<bool> (????) enable frame drop (default=off) smooth=<bool> (??????) enable smoothing (default=off) 24fps=<bool> (24fps?) force 30fps->24fps (default=off) tune=<bool> (?????) show scan result (default=off) rff=<bool> rff flag aware (default=off) timecode=<bool> output timecode (default=off) log=<bool> output log (default=off) --vpp-rff apply rff flag, with avhw reader only. --vpp-tweak [<param1>=<value>][,<param2>=<value>][...] apply brightness, constrast, gamma, hue adjustment. params brightness=<float> (default=0.0, -1.0 - 1.0) contrast=<float> (default=1.0, -2.0 - 2.0) gamma=<float> (default=1.0, 0.1 - 10.0) saturation=<float> (default=1.0, 0.0 - 3.0) hue=<float> (default=0.0, -180 - 180) --vpp-pad <int>,<int>,<int>,<int> add padding to left,top,right,bottom (in pixels) --vpp-select-every <int>[,offset=<int>] select one frame per specified frames and create output. --vpp-delogo <string> set delogo file path --vpp-delogo-select <string> set target logo name or auto select file or logo index starting from 1. --vpp-delogo-pos <int>:<int> set delogo pos offset --vpp-delogo-depth <int> set delogo depth [default:128] --vpp-delogo-y <int> set delogo y param --vpp-delogo-cb <int> set delogo cb param --vpp-delogo-cr <int> set delogo cr param --vpp-perf-monitor check duration of each filter. may decrease overall transcode performance. --cuda-schedule <string> set cuda schedule mode (default: sync). auto : let cuda driver to decide spin : CPU will spin when waiting GPU tasks, will provide highest performance but with high CPU utilization. yield : CPU will yield when waiting GPU tasks. sync : CPU will sleep when waiting GPU tasks, performance might drop slightly, while CPU utilization will be lower, especially on HW decode mode. --output-buf <int> buffer size for output in MByte default 8 MB (0-128) --max-procfps <int> limit encoding speed for lower utilization. default:0 (no limit) --output-thread <int> set output thread num -1: auto (= default) 0: disable (slow, but less memory usage) 1: use one thread --log <string> set log file name --log-level <string> set log level debug, info(default), warn, error --log-framelist <string> output frame info of avhw reader to path --perf-monitor [<string>][,<string>]... check performance info of encoder and output to log file select counter from below, default = all counters for perf-monitor all ... monitor all info cpu_total ... cpu total usage (%) cpu_kernel ... cpu kernel usage (%) cpu_main ... cpu main thread usage (%) cpu_enc ... cpu encode thread usage (%) cpu_in ... cpu input thread usage (%) cpu_out ... cpu output thread usage (%) cpu_aud_proc ... cpu aud proc thread usage (%) cpu_aud_enc ... cpu aud enc thread usage (%) cpu ... monitor all cpu info gpu_load ... gpu usage (%) gpu_clock ... gpu avg clock vee_load ... gpu video encoder usage (%) ve_clock ... gpu video engine clock gpu ... monitor all gpu info queue ... queue usage mem_private ... private memory (MB) mem_virtual ... virtual memory (MB) mem ... monitor all memory info io_read ... io read (MB/s) io_write ... io write (MB/s) io ... monitor all io info fps ... encode speed (fps) fps_avg ... encode avg. speed (fps) bitrate ... encode bitrate (kbps) bitrate_avg ... encode avg. bitrate (kbps) frame_out ... written_frames --perf-monitor-interval <int> set perf monitor check interval (millisec) default 500, must be 50 or moreusers currently on my ignore list: deadrats, Stears555, marcorocchini
Announcing QtlMovie, a specialized graphical front-end to FFmpeg
By lelegard in forum Latest Video NewsReplies: 58Last Post: 9th Apr 2017, 14:33 -
Video convertor that uses Nvidia Nvenc
By amirzubair in forum Video ConversionReplies: 7Last Post: 19th Jul 2015, 08:20 -
Can someone add batch encoding to this x265 ffmp front end (written in ahk)
By ezcapper in forum Video ConversionReplies: 0Last Post: 5th Jul 2015, 14:13 -
Nvidia NVENC HEVC is better than x264
By sophisticles in forum Video ConversionReplies: 10Last Post: 25th Mar 2015, 13:27 -
ffmpeg with '--enable-nvenc'
By Selur in forum Video ConversionReplies: 1Last Post: 13th Jan 2015, 06:45
