Hi everyone.
I have a problem with some videos, in my computer they work fine, but in my TV LG32cs460 the audio fade after 15 minutes playing.
MediaInfo:
General
Complete name : I:\RK\RKMKR-01.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 50.3 MiB
Duration : 23mn 12s
Overall bit rate : 303 Kbps
Encoded date : UTC 2012-03-02 03:19:44
Tagged date : UTC 2012-03-02 03:19:44
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Duration : 23mn 12s
Bit rate mode : Variable
Bit rate : 268 Kbps
Maximum bit rate : 1 378 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.029
Stream size : 44.5 MiB (88%)
Writing library : x264 core 83 r1391 3d0f110
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=268 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2012-03-02 03:19:52
Audio
Format : AAC
Format profile : HE-AACv2 / HE-AAC / LC
Codec ID : 40
Duration : 23mn 12s
Bit rate : 32.0 Kbps
Maximum bit rate : 34.9 Kbps
Channel(s) : 2 channels / 1 channel / 1 channel
Channel positions : Front: L R / Front: C / Front: C
Sampling rate : 44.1 KHz / 44.1 KHz / 22.05 KHz
Compression mode : Lossy
Stream size : 5.31 MiB (11%)
Encoded date : UTC 2012-03-02 03:19:51
Is there something I can do with the audio?
are these movies on a burned blue ray or dvd disc?? if so then it is Cinavia.
in order to play on your tv you will need to use an older bluray or dvd player
or you can use a media player of some kind which are immune to Cinavia protection. -
Convert the audio to constant bitrate ... hardware which has fixed preset find variable audio hard to handle ... computers don't care.
How to Fade In/Fade Out Audio Clips in VSDC Free Video Editor?
By BSquared18 in forum EditingReplies: 15Last Post: 6th Mar 2015, 21:44 -
Any free video editing software that does audio fade in/out?
By Juror No. 8 in forum EditingReplies: 3Last Post: 27th Jul 2013, 01:50 -
Audio Fade in/out plugin for VirtualDub
By aaxpers in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2012, 13:00 -
avisynth to fade audio but not video
By adom in forum Video ConversionReplies: 9Last Post: 5th Oct 2011, 15:51 -
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45
