I had times when my DVD drive reads my disc and it generated loud noise. I forget exactly how it happened but I found the disc very hot, like being heated up, after ejecting it out from the drive. And I gave up the drive.
I also had times with trying different DVD encrypter program that said to bypass DVD protection (but none of them works or I am not good enough with computer) . I remember some of them returned with message like ''your disc is altered...'' or ''your disc is modified'' or ''your disc is encrypted''
I forget the exact terms.
My question is
1. In either case, could my disc be altered anyway or hurt?
2. Is DVD disc (pressed or DVD-R) designed to hold data over time and endure discipline??
Results 1 to 15 of 15
The laser and other rotating parts don't touch the disc unless the player or disc is badly damaged. Then you will usually see circular scratches.
If the disc already has damage, the drive will try to re-read the disc several times before giving up.
That can warm up the disc from the heat of the laser, and the drive motor can also heat it up. But that's not likely to cause any disc damage.
How long a DVD lasts is a whole other discussion. The factory stamped discs should last quite a bit longer than burned discs.
But with either disc, quality makes a big difference, especially with burned discs.
Some cheap DVD discs may only last a very short time before they have playback problems.
Most all commercial pressed discs have encryption. We have several decryption programs listed in our 'Tools' section. -
Avoid slot-load or pinch-load players like this one.
http://gpx.com/d202b.html -
Hi, thank you and other's comment
I have a few more questions hope it's not too dummy
1. If laser or dvd player does not touch the disc, how can we write files to a blank disc ??
2. During / After the decryption process, would the original disc be altered or changed in any way? Or if the program creates temporary space on hard drives and put the decrypted version there while keeping the original disc *original*??
Thank you -
A laser shines through the air gap and protective plastic layer and "burns" the data onto the internal recording layer.
No. Unless the drive is defective and the read head gouges scratches onto the surface. Or a defect in the disc causes it to fly apart while spinning. Both of these are very rare usually very obvious.Last edited by jagabo; 29th Oct 2015 at 07:27.
I get dvd's from the library. They have 'stickers' to identify them, some older ones have wire threads under a clear dvd sized 'like scotch tape' to hold the wires. In both computer drive & dvd player, the high speed rotation of some of them causes them to 'jump' and wobble around causing major scratches on the disks. Aparrently, they are enough out of balance that this happens. This does (rarely, tho) happen to disks without anything attached/stuck on. Bad ones get through QC.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
In fact I have tried MANY MANY (no lie ) trial or free version ( of those applications that claim to decrypt (btw, how to spell??) DVD discs but I do not succeed in getting my copy-protected disc decrypted ......
what is the reason? Only the paid version would work or if my disc (beautiful discs with beauftiful cover, original and authentic) has employed very new way of protecting the disc itself?? -
Any recommendation on brands of DVD writer (no blue-ray is needed) ?? Or if any cheap of them are just good enough ??
Most of the name brand DVD writers perform about the same in my opinion, Samsung, Asus, LiteOn, etc.
Panasonic SA-BTT270 DVD player doesn't recognise disc
By allycat in forum DVD RippingReplies: 13Last Post: 19th Sep 2014, 09:54 -
The once again new Ebay policy changes to hurt sellers even more.
By MeDiCo_BrUjO in forum Off topicReplies: 18Last Post: 19th Dec 2013, 21:58 -
New here - need help - Disc won't play on my basic dvd player
By thompson615 in forum MacReplies: 9Last Post: 21st Mar 2013, 13:14 -
Does rendering to same format hurt quality?
By R Man in forum Video ConversionReplies: 8Last Post: 22nd Nov 2011, 19:14 -
Philips 3000 series Blu-ray Disc/ DVD player Walmart $128
By imars99 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Aug 2011, 03:08
