Hello, does anyone know how a .vrd format shot by a security camera can be played? I really haven't heard of this format until now. I suppose it could be by Sony, because they have VRD camra series
Results 1 to 9 of 9
Often security footage is encrypted. If that's the case for you, only the device or the included software can play it
Yes, I suppose it's encrypted too, btw I have a 132 bytes file, it could be the key. But I really don't know what software to use, I'm not sure about the device that shot the video... what can I do?
Find out the device /model number and search the manufacturer site for software / codec /driver.
You can try VLC, which can play most things. But when mediainfo shows nothing, it usually means the file is either encrypted or damaged. The header information that is supposed to be there that enables videos to play "normally" in "regular" software isn't where it's supposed to be. So it's very unlikely that you'll be able to do anything without the other information -
I already tried that... but aren't they using encryption standarts like aes,des,rc4... or camera makers have their own. because if they are using standards I can try to decrypt the file with some of them
Edited with VRD now need music?
By mccoady in forum EditingReplies: 12Last Post: 2nd Aug 2015, 13:05 -
Sony DV Direct VHS to DVD Conversion Problem with Model VRD-MC6
By WRArtMonk in forum Newbie / General discussionsReplies: 19Last Post: 8th Dec 2012, 19:08 -
Sony VRD-MC6 Connection To Cable Box
By Lindon in forum DVD RippingReplies: 4Last Post: 29th Sep 2012, 19:53 -
Adobe Premiere to Sony DVD DirectRecorder (VRD-MC6)?
By B11 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st Jan 2012, 13:12 -
SONY DV Direct VHS to DVD Conversion Issue with VRD-MC6
By WRArtMonk in forum Video ConversionReplies: 1Last Post: 6th Jan 2011, 09:51
