Page 2 of 2
FirstFirst 1 2
Results 31 to 35 of 35
  1. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    PP = premiere pro. ie. what he is using. Premiere writes cache files (audio peaks, metadata, conforming data) - this is why a 2nd HDD for media is almost mandatory. Mechanical HDD's (and early gen SSDs) have very difficult time with multiple access reading and writing simultaneously . For AE , it'is even more important to have another fast storage, because of RAM previews - it caches all intermediate states, not just the current ram preview (old ram previews as well)
    Yes, lagarith is supported in PP, but it's too slow . The only "usable" mathematically lossless codecs for editing purposes (low latency) are ut video and magic yuv. For near-lossless, cineform would probably be the "best". Even UHD/4K is usable on a laptop like his with cineform.
    This is for youtube.
    Originally Posted by Blbr View Post
    @KarMa It's all right. No one is taking anything personally. By 720p I meant that I would like to edit at least at 720p without any lag, I didn't mean to say that it was what I edit all the time. I wonder if avc1 codec is any better? And yes, you may not know what I really do, but that's only because it's not necessary. Like you said, I am not going to go through all the trouble of converting, it would take way too much time with this laptop.
    Download MediaInfo, and put your MP4s in it. Should give you lots of info about it.
    AVC1 is just one of the fourcc labels for H.264 I think. Don't believe it means much.
  2. @KarMa Yeah, that's what I thought, it is avc1.
  3. Originally Posted by KarMa View Post
    Yes, and he's using premiere. I'm just explaining the facts and why those suggestions were made earlier regarding media choices. Premiere and AE don't work like vdub or videoredo.
    You're the one who brought up FFV1 and lagarith. I'm just clarifying that there are better editing choices for lossless codecs if he was going to go that route
    All he wants is "snappier" editing. Memory is an issue for him and storage is an issue for him
  4. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Can you give me this part from Mediainfo (View ---> Text)
    example
    Video
    Format : AVC
    Format profile : Baseline@L4
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Muxing mode : Container profile=High@3.1
    Codec ID : avc1
    Duration : 18s 600ms
    Source duration : 18s 567ms
    Bit rate : 3 138 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 fps
    Minimum frame rate : 29.412 fps
    Maximum frame rate : 30.303 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.050
    Stream size : 6.95 MiB (99%)
    Source stream size : 6.96 MiB (100%)
    Writing library : x264 core 146 r2538 121396c
    Encoding settings : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=9 / lookahead_threads=1 / sliced_threads=0 / nr=100 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc_lookahead=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=10000 / vbv_bufsize=10000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=0
    Pretty much tells me nothing about what you are doing but I can still look at the video complexity. This is a recording I made with Open Broadcaster Software, x264. This is just an example and I don't advocate these settings.
  5. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    [QUOTE=poisondeathray;2416651][QUOTE=KarMa;2416648]
    If we only knew how complex these projects were. I'm assuming it's less, you are assuming it's bigger. How do you feel about cattle prices?
    I would suggest avisynth but that's a bit of a hurdle.
    It was a big file I had to show what a fragmented 5400rpm drive could do with a 18GB file. If he is dealing with lossy x264 to begin with then drive speed is even less of a concern.
    I may have missed my stop but I'm getting off this Blue's Clues train.
