My goal is simple, use x264 vs AME to encode my ProRes HQ 1920x1080p30 content for Encore without triggering the transcode flag for Blu-ray.
I am able to do that successfully if I downscale to 720p60 using the 720p60 command from here.
However, I am not real happy with the results and would like to retain the 1080p resolution. I have tried various ways of encoding the content without downscaling, but all of them so far trigger the transcode flag.
I know that only 1080i60 is BR compliant. I also know that --pulldown double is not supported in Encore. I thought --fake interlace would do the trick. But apparently not.
Any suggestions? Or should I just forget 1080 for BR? Thanks.
--fake-interlace works, or at least it has in the past in encore
The other option is to encode MBAFF with --tff -
Are you saying --fake-interlaced doesn't work? Just checked - seems to work ok still
Improving seek in x264 encodes
By Surlias in forum Newbie / General discussionsReplies: 60Last Post: 1st Sep 2015, 08:59 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 02:14 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 11:35 -
Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?
By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 12:45 -
So what x264/MeGUI settings will Adobe Encore ultimately like?
By Asterra in forum Video ConversionReplies: 28Last Post: 16th Dec 2011, 15:40
