What im asking is:
How can i burn a movie (avi, mpg...) into VCD and have subtitles (i add of course) in the movie. I'm not sure how to add subtitles, so im not sure if im supposed to add the subtitles with a program or what... help. thx.
You cant add subtitles to a normal vcd caus MPEG-1 dont support it. SVCD will let you. If you need to add your own, I-Author does a good job of it. You will need a copy, and they are very hard to find.
You can find a guide here
http://www.vcdhelp.com/svcdsubs.htm
if you need anything post hereNeed a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG -
You can add subs (permanently, not switchable, sorry) in VirtualDub with a 3rd party filter and some work, then frameserve to your mpeg encoder (TMPGenc, for instance). Grab the filters from virtualdub.org
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
K, i read and downloaded everything i need. Tomorrow ill try and use my stuff to add subtitles to a movie. (VCD)
Its not that difficult...
thx
Need help getting burnt in subtitles for video
By TheGasMaster4381 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2010, 17:04 -
How to merge subtitle file with movie when it is being burnt ?
By dilanalex in forum SubtitleReplies: 3Last Post: 7th Apr 2009, 04:15 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 20:40 -
Adding burnt in subtitles to an existing MPEG2 file
By netmask56 in forum SubtitleReplies: 3Last Post: 18th Aug 2007, 01:22 -
Removing burnt in subtitles
By Egat in forum SubtitleReplies: 0Last Post: 15th Aug 2007, 03:38
