    Nov 2006
    Libyan Arab Jamahiriya
    I want to use (x264vfw - H.264/MPEG-4 AVC codec), but the compression options are not available ..
ID:	34238Click image for larger version
    any ideas please?!
  2. 32 bit vs 64 bit? 32 bit programs can only use 32 bit codecs. 64 bit programs can only use 64 bit codecs.
    Nov 2006
    Thank you, but this program's version is 64 bit .. or do you mean I should install 64 bit codecs? .. if so, I had a 64 bit version of (x264vfw - H.264/MPEG-4 AVC codec) installed already.
  4. 64 bit programs can't use 32 bit codecs. I don't know if Power Director uses VFW codecs.
