Hi there.
I encountered a strange error after joining mts files from my canon xa10 camera. There seems to be an overlapping in the first part of the video as if second and third clip are somehow merged together and not joined. When I play the resultant file in potplayer, when the video reaches the time of second clip, it goes on ok, but when I press seek forward, the player switches to the other clip which should actually be the third one. When I don't press anything, the second clip plays. So it's like first clip is ok, then second and third clips are on parallel tracks, and then fourth and further parts are ok again. I have no idea how it's possible for such a thing happen since I used the program File Joiner and it would not just join clips which doesn't match up. And now what to do? How can I cut it apart again, separate the second and third clips and put it back together? When I open the file in Vegas Pro, it comes up as one track and the third part starts after the first one, so second part is hidden. First time encounter such a thing.
I deleted the original ones before checking the output... Classical mistake. And I don't like tsMuxeR, it doesn't keep the a/v in sync. You can use the time delay, but I prefer a program which can figure out such a basic thing by itself.
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21 -
PGS time/time position after merging MTS files to MKV
By MrRalph in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Aug 2014, 14:50 -
Merging MTS files - What a time sucker; is there another way?
By sdsumike619 in forum EditingReplies: 3Last Post: 18th Oct 2012, 12:31 -
noise where joined 2 avi files
By coyote2 in forum EditingReplies: 20Last Post: 13th Oct 2011, 22:19 -
Joined MTS files from Panasonic HDC-SD70, create audio delay...
By pleindepuces in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Dec 2010, 16:29
