Hello all,
I have a couple of fundamental encoding questions that I hoped someone could answer.
1) Is there a guide anywhere that explains when and where, in TMPG, to set the Video Stream aspect ratio, and the Output aspect ratio (on the Advanced tab), to produce a particular display for a given movie format.
E.G., if I have a 16:9 movie source and I want to end up with a letterboxed output, what settings do I use? Is there a nice little cross-reference-type table for all possible situations in some guide somewhere?
2) When is it advisable to crop your movie? I have never done this, but have ended up with viewable results. Where is it beneficial to do this, and if you do, does it reduce the resultant file size after encoding?
Thanks in advance for any feedback
Results 1 to 1 of 1
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 03:53 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 04:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 09:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 19:59
