I Just downloaded my first movie, but I do not know how to play it. The file looks like this - ffbowcd1.r16
I have 40 of these files, do I have to convert them? Thanks for the help.
Results 1 to 23 of 23
You most likely have downloaded a so-called RAR file. WINRAR is the program you need which you can download at http://www.download.com will check the 40 parts (the end number is usally the part no. of the file i.e. in your case part 16) and fuse them back together again.
Thanks for the help! I downloaded that program, what do I do now to use that program to allow me to view the video? Thanks
Winrar is merely a compression tool - you might know winzip also a compression tool. What zip files are for winzip rar files are for winrar. Once you have un-rared (unzipped) the files you downloaded you should get one big file. It might be a avi or mpeg. Then you have to work from there.
Hey Aldus4 thanks a lot for the help. Not I have two files, cd1.bin & cd1.cue
What do I do next? Thanks Again. -
Lol. You must have downloaded a ready-made VCD.
You must use a CDRWIN to burn it to disc. Go to the same download.com to get it. -
OK you have unzipped the files and received 2 new files called bin and cue. The bin file is an image file. The cue file is more or less the index file for the accompaning bin file. Which burning software do you have? Normally you would burn this to a CD-R(W) and the you would have a VCD or SVCD etc. You can however if you want to see the clip before you burn it, download some software to (lets call it) un-bin the bin file. If you go to the tools section of this website you can find CDMage which can extract the files you would want. You could also use some other software, but I think you'll find CDMage more managable.
Ok I downloaded that program and then it asks me to "Select Image Type Of The File', which one do I select? Thanks!
If you select the cue it should direct you to the bin - or you can choose the bin directly.
OK - in CDMage you saw a file structure. If this was a VCD you should have seen a directoy called MPEGAV. In this directory you will find 1 or various dat files. These dat files are encoded mpeg1 formated files. You now need to download VCDGear (also in the tool section of this website) to convert the dat file into an mpeg1 file. This should then be playable in your WIndows Media Player.
Is this the version I download? VCDGear v1.6d Final(Console) Windows 9X/NT/2000 i386 Download
If so I have already, now what do I do next. I tried opening the VCDGear Program and nothing happens? -
Well I have VCDGear 2.0 which comes with a GUI. Try downloading that version if your version doesn't work. Choose dat-->mpeg. Click on the load button (here you choose the dat file) and then a "save as" window will appear - name it - and you're off...
Ok, man I really appreciate your help. I got the VCDGear 2.0 and that works. When I try to load the BIN file I get an error. Do I have to save or extract the dat with CDMAGE first?
...I thought you had. Yes, use CDMage to extract the dat file. Then use VCDGear to convert the dat to mpeg1.
Ok finally I did it. Thanks so much, I couldn't have done it without your help. Now if your not to annoyed with me, is there anyway I could burn the mpg to a cd and play it in my DVD player? Thanks again man!
Annoyed me? NEVER <grin>
I asked you before which burning software you are using....still waiting for reply. -
OK use the VCD template load the mpeg1 file and burn - if you want to add a menu you can of course.
Have to dash off now - good luck
No offense, but if you would have listened to me when I said to burn the bin/cue with CDRWIN you could have saved so much time and bother because it's obvious that you downloaded a ready-made VCD that only needed to be burned.
@GUTB
..but he didn't have CDRWIN
Also I am against waste...what would have happened if the bin/cue would have been soething he didn't like <grin>???
@khai
ROFL
I was in a rush actually.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
VCD
By dodd22 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 17:01 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
VCD
By rocketboy in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 15:06 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
