  1. The purpose of the exercise is to stream the films using Plex which will not use Video_ts.
    Using MakeMKV I am remuxing some old tv recorded films from VIDEO_TS (MPEG-2) which, using MediaInfo shows pixel size 720x576.
    The resultant MKV shows the size as 352x288. The same happened regarding a previous post by me regarding a similar episode with DV tapes.
    There are no settings to alter this.
    Can somebody explain please?
    Can I correct it?
    No. Makemkv does not reconvert. Your DVD is 352x288.
    The vob contains the video:
    Complete name                            : E:\VIDEO_TS\VTS_01_2.VOB
    Format                                   : MPEG-PS
    File size                                : 602 MiB
    Duration                                 : 53mn 55s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 562 Kbps
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Custom
    Format settings, GOP                     : M=3, N=12
    Duration                                 : 53mn 55s
    Bit rate mode                            : Variable
    Bit rate                                 : 1 275 Kbps
    Maximum bit rate                         : 9 549 Kbps
    Width                                    : 352 pixels
    Height                                   : 288 pixels
  3. Thank you very much Baldrick
    I see that I used the Video_TS folder with mediaInfo and seeing what looked like a valid report accepted it, not knowing any better.
    I don't really see why MediaInfo doesn't understand that it must find the vob.
    I find it incredible that standard TV could look OK with so few pixels, that is why I believed what I did.
    Will you please say whether my converting with MakeMKV and presenting it with the Video_ts folder is OK or should I present the vob only.
    It's ok to use MakeMKV. As long as the mkv with mpeg2 video works ok in Plex.
