  1. Hello there,
    I was recording a video message with my webcam using 'Free Screencast' software.
    The settings i used where like this:
    FFDshow video encoder:
    • Encoder: MJPEG
    • FOURCC: MJPG
    • Mode: 1-pass Quality
    • Recording Format: AVI
    But now with every possible player i get the same output:
    The pixels change very fast and and are all colored.
    I can see some sort of movement which should be my head but its far from natural and al pixalated noise.
    I think the frames should be combined or something to get the right colors and frames back but i have no idea how to fix this.
    Is there somebody who can give me a kick in the right direction
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Open the file using mediainfo? Are the file specs properly identified? I'd guess not, which means it's just garbage.
    Google is your Friend
