While shopping for cheap DVD-R media, i took a look at http://www.cd-recordable.com and what should i see but Double-sided DVD-R discs for General Use. Has anyone tried these yet? Can anyone verify that they work?
as I understand it, all they are are a disk, with both top and bottom recordable
Yes, I have used several of them. They are the same as the regular ones. Now they cost more than just buying 2 of the one sided ones, but its still great to have.
I've purchased some from them. No problems at all. It's just a disc with 4.7GB on one side and 4.7GB on the other. I've found it pretty convenient. Since the Farscape discs have two episodes and don't fit on one side, I burn one episode to one side and the other to the other side.
You can get 100 9.4 gig double sided dvd-r discs for $450.00 and no shipping cost to the UK. They work fine in dvr-103 and pioneer 343 player. http://store.yahoo.com/dvd-r/dvexpac.html
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40
