I finally get a 1280x720 output from VidCoder. Setting anamorphic to none, unchecking "keep aspect ratio" will produce a 1280x480 output. I changed the settings to anamorphic = none, check "keep aspect ratio" and set cropping to none. This will produce a 1280x720 output.
Sample 1280x720:
https://zorofiles.com/2l8n9urfoy5o
The difference I see, between 1280x828 and 1280x720, when I play the video on laptop using media player, is the 1280x828 video has 2 vertical bars on the side, the media player window occupies the entire laptop screen with the 2 vertical bars on the side, while the 1280x720 video has no vertical bars on the side, the media player window of the 1280x720 video is like 0.5 inch shorter than the window of 1280x828 video as the 1280x720 video lacks the vertical bar.
In any case, thank you all for the education.
Results 61 to 61 of 61
Should I rip standard def DVD to 1280 x 720?
By zBernie in forum Newbie / General discussionsReplies: 9Last Post: 17th Jun 2014, 10:49 -
Help with Handbrake: Ripping music videos from DVD to MKV
By Juror No. 8 in forum Video ConversionReplies: 2Last Post: 25th Jul 2013, 05:27 -
with what software shall I edit/join hd (1280 x 720) you tube videos
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 11th Feb 2013, 22:03 -
DVD screen to 1280 * 720 (Handbrake)
By Hydra in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2012, 03:13
