Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 61
  1. I am completely new to ripping videos from DVD and HandBrake. I want to rip some videos from DVD to mp4 format. So I used HandBrake to rip the video from DVD and the video output was successfully coverted to mp4. But the video size is 720 x 466 instead of the 1280 x 720 format. I used the default settings in Handbrake.
    What settings do I need to change in HandBrake to convert the original DVD 720 x 480 video size to 1280 x 720 video size?
  2. DVDs are encoded at 720x480 or 720.576. Handbrake never increases the frame size.
  3. Originally Posted by jagabo View Post
    I see, learning something there. What software should I use next to convert the 720 x 466 video to a 1280 x 720 video?
  4. Originally Posted by videobruger View Post
    Vidcoder. A frontend for HandBrake.
    Do I need to uninstall HandBrake to use Vidcoder? Can both Vidcoder and HandBrake co-exists?
    One problem is, according to the developer's website, Vidcoder does not defeat CSS encryption so I would still need to use HandBrake with libdvdcss-2.dll.
  5. How about just sticking to HandBrake and use another software to convert the 720x480 video to 1280x720 video?
    What video conversion software would you recommend?
  6. Why does it have to be 1280x720? It's not as if you're actually creating a hi-def video from a standard-def source. It's not going to look any better than it does on the DVD.
  7. I wanted a "full size" video upon opening
  8. Tried this: http://www.videotovideo.org/
    100% free software and no malware embedded
    Converts 720x480 to 1280x720 but:
    - output video is not 16:9 even though "16:9" is selected
    - quality is worse than original video from HandBrake
    Tried both HandBrake's loose and strict outputs, both has the above 2 issues.
    Verdict: VideoToVideo not a keeper
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Full size??? No black borders???
  10. Originally Posted by Baldrick View Post
    It's not just me then? I was completely baffled by his response and decided not to say anything more.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Just zoom in your video player. FULL SCREEN.
  12. Originally Posted by shenton View Post
    I'd consider re-thinking that. Most hardware players upscale to fullscreen by default (including any black bars that might be required, of course), and for software players that don't have that option, fullscreen mode is only one mouse click away. MPC-HC has an option to launch files in fullscreen mode. I can't imagine it'd be a good idea though, unless you're opening them fullscreen on a monitor that's only used for watching video, otherwise it seems like a recipe for annoyance to me.
  13. I suspect your player isn't respecting aspect ratio flags. Turning off anamorphic encoding in Handbrake should take care of that.
  14. Originally Posted by Baldrick View Post
    Black borders does not matter. I am viewing the videos on a laptop.
    There was a reason why I included that YouTube 1280x720 in the screenshots. Those 1280x720 videos, when you open the video, it fills up the entire screen, with or without black borders. That was what I meant when I say "full size".
    The 720x480 video output that I get from HandBrake does not fill up the entire screen when I open the video, not unless the window is maximized.
    I wanted to be able to create 1280x720 (16:9) videos just like those videos from YouTube.
  15. Originally Posted by jagabo View Post
    No difference, video output is still 720x480 when anamorphic is turned off in HandBrake.
    I did wanted anamorphic 16:9 video.
    May 2014
    Memphis TN, US
    [EDIT] Had to read back posts several times to get what you're saying.
    Too bad we have no detail info, no sample image or video, no MediaInfo on your original source. Could be your DVD isn't a full 16:9 video,but is maybe 1.66:1 with slight letterbox borders (and maybe that's why Handbrake is giving you 720x466).
    I'll echo a couple of others. We don't know what your original source really looks like, so I'll just let the others keep guessing.
    - My sister Ann's brother
  17. Originally Posted by shenton View Post
    Then you did something wrong. Handbrake clearly sees that your source is 16:9. When you turn off anamorphic encoding it should have given you about 720x404 (a little less since it's cropping black borders).
  18. Originally Posted by LMotlow View Post
    Are you saying you do want anamorphic, or you do not want anamorphic? EVen if you get 1280x720, that format is already square-pixel 16:9, not anamorphic. Maybe a typo in your last post?
    I'm a newbie in videos, let's leave the anamorphic aside, I want a 1280x720 video.
  19. Originally Posted by jagabo View Post
    I used the default Handbrake settings. Only tweak the anamorphic drop down because I'm not getting a 1280x720 output.
    In any case, you are talking about an output of 720x404, that's not what I want, I want an output of 1280x720.
  20. Originally Posted by shenton View Post
    Doesn't the definition of "full size" change according to the resolution of the monitor? A 720p video might open "full size" on a monitor with a resolution of 720p or lower, but it won't if the resolution is higher. What happens if you switch to a higher resolution monitor at some stage?
    I don't understand the need for upscaling myself when you can usually configure a player to run in fullscreen mode by clicking on the video in some way after it opens, or for the player to open in fullscreen mode automatically, and I don't mean maximising the player window, I mean running the video fullscreen without the player window. Or you could configure the player, or the shortcut you use to open it, so the player automatically opens in a maximised state, if you're into that sort of thing. Of all the available options for filling the screen, upscaling and encoding additional picture without any increase in picture detail, seems the least practical to me.
    What media player are you using? If it's not displaying the video with a 16:9 aspect ratio it's probably the players fault, but the aspect ratio shouldn't change when the video is upscaled to fill the screen, just the size of the picture.
    MPC-HC can tell you the exact aspect ratio using the File/Properties menu. VLC probably does something similar. The first aspect ratio is the one being used to display the video without upscaling. It's not always exactly the same as the second aspect ratio as the resizing has to be rounded to whole pixel dimensions.
    Looking at your Handbrake settings, it should be encoded with a 720x480 resolution (not including any cropping) and display with a resolution of 854x480 (16:9). If your monitor's resolution is greater than 854x480 it generally won't use any more screen real-estate until it's running in fullscreen mode or the player is maximised.
    Each to their own, I guess.....
  21. I'm a Super Moderator johns0's Avatar
    canada
    Handbrake won't upscale videos,use vidcoder to do that,it was already suggested.
  22. Originally Posted by shenton View Post
    Unless Handbrake's changed recently, it won't upscale, so you'll have to use something else (ie Vidcoder). For Handbrake the maximum width/height is the original width/height. By default (cropping aside) I think when anamorphic encoding is disabled, Vidcoder resizes 16:9 DVDs to 854x480 (NTSC) or 1024x576 (PAL) but I can't remember if it'll let you upscale further.
  23. Member
    May 2014
    Memphis TN, US
    We're just guessing. I make one more guess and bet that the DVD is encoded as 16:9 but the image itself isn't 16:9.
    Interlaced DVD to 1280x720...I think I see what's coming. Do we ever get a break from this sort of thing?
  24. Before I messed my computer up, do I need to uninstall Handbrake before I install VidCoder?
  25. I'm a Super Moderator johns0's Avatar
    canada
    Nope.
  26. Ok, I'm going to install VidCoder without uninstalling Handbrake. I'll keep both on my computer.
    Thank you all.
  27. VidCoder works, I'm getting a 1280 width video:
  28. Member
    May 2014
    Memphis TN, US
    1280x828? That's not 16:9.
  29. You're right. It's roughly the same aspect ratio as it's stored on the DVD (1.5:1) minus the cropping. So, VidCoder may work but you still have to know what you're doing. There's not really any point in setting aspect ratio flags when making Hi-Def encodes. And, with a DVD source I don't see the point in upscaling at all, even with that I wanted a "full size" video upon opening nonsense.
