I have searched the settings long & hard viewed ini files & I don't know how to do this. Just won't to disable any function spacebar does. It's too easy to accidental press & serves me no use, just looking for the simplest way to achieve this? Searching on google was not bringing up anything specific.
If anyone uses this & knows. thanks
It seems IrfanView's keyboard shortcuts are 'hardcoded', i.e., we the users cannot modify or remove them : -/
[SOLVED-?] Spyware in the JXR plugin for IrfanView?
By El Heggunte in forum ComputerReplies: 3Last Post: 25th Apr 2014, 12:37
