  1. Hello All,
    I have mpg file which is the output of joining two mpg files , it's timestamp is not right .
    The length of the file (as displayed in it's info) is only of the second file , when it's played in VLC It counts to from 00:00 till it reaches the joining point then back to 00:00 and up till the end.
    in other players (WMP & MPC) it reaches the end of the indicated length then continues playing without the ability to go back or forth.
    is there a solution for this that keeps the file's audio video sync intact ?
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Various players may play a video that is incorrectly joined but the total time , seeking, etc. may not work. It sounds like this a case where the 2 videos may have been joined incorrectly.
  3. Thank You for your reply.
    is that hopeless case ?
    What did you join with? Several joiners are crap....
    Or try "remux" the joined mpg as it might fix the headers:
    Add the mpg in avidemux, under video and audio choose copy. Format mpg. Save as a new mpg.
    Or use the old tmpgenc, under file->video tools, simple multiplexer add the mpg and make a new mpg.
    Or use ffmpeg, ffmpeg -i video.mpg -c copy newvideo.mpg
  5. Thanks a lot for that solution Just tried ffmepg and it did work perfectly.
    I used TSplayer to join the files , It was the only joiner I Tried that didn't alter audio video sync of my DVB recorded files after trimming ads.
    This Thread Should be Marked as Solved
