Hi there,
I've created a DVD in DVD Lab Pro 2 and everything works fine except the chapter points. I added them by importing a txt file and in the movie window they are in the right spots.
When I export the DVD and open it in Power DVD or VLC Player and select any chapter the program seems to jump to the right timecode but it's not the right point in the movie. The chapter points are all in wrong places sometimes up to two minutes off.
Did anybody here have a problem like this?
I've indexed, demuxed, debugged and tried every setting but it's still the same. The Mpeg is ok, closed GOPs, short GOPs, I-Frame length of 9.
Thank you!
Have you tried author with anything else? Just add some chapters points and make a dvd with for example dvd styler.
DVD LAB PRO 2.52 Transitions
By litost88 in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2016, 14:56 -
[DVDLAB PRO] Help, I need to change region DVD in DVD LAB Pro
By kirous in forum Newbie / General discussionsReplies: 25Last Post: 16th Jul 2015, 08:07 -
DVD Lab Pro help
By b2kguga in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2015, 15:09 -
dvd lab pro - playlists
By Master.Rabbit in forum Authoring (DVD)Replies: 6Last Post: 28th Mar 2013, 08:11 -
I Need Help with DVD Pro lab
By derr_eng in forum Authoring (DVD)Replies: 20Last Post: 31st Aug 2012, 22:09
