anyway, since i can't go further and have to cope with the color change effect, as the last try i made the whole clip and go to share it with you to thank you for your guides.
here:
https://dl.dropboxusercontent.com/u/4829119/10-08-12%20-%20IRIBTV4.mkv
Results 61 to 76 of 76
VLC and MPCHC give the same levels on my computer. Your original TS file and the MKV file you just uploaded also give the same levels. Something is wrong with VLC's configuration on your computer. Or possibly the video renderer. Try the different Output devices in VLC. Windows GDI should give you the correct levels but it's the least efficient. You need to stop and restart (not pause) playback in VLC for the change to take effect.
In the Simple view it's just Output. In the All view it's Video Output Module.
it's finally to be played back on tv set. if so, not to worry about?
i examined all of the options and they didn't change the output appearance.
maybe this is because my graphics card? i didn't install the manufacturer's driver (nVidia). Windows 7 default driver is used. -
There is a Dynamic Range option in the Video section of the Nvidia setup applet. Make sure it's set to Full (0-255).
yeah i tried it with restarting playback (stop, not pause, then play) as well as restarting the player (vlc). but nothing changed. maybe i've to learn how to use and work with virtualdub instead of avidemux for converting through a script.
i didn't have time last night at home to download the driver for my graphics card (nVidia GeForce 6200). i hope i'll do it tonight. -
i installed the display driver tonight. the result is the same.
Did you set the Dynamic Range option?
In any case, your levels problem is limited to VLC so you shouldn't worry about it. Just use another player.Last edited by jagabo; 5th Nov 2015 at 20:15.
yeah, that's it. the dynamic range solved the problem.
what is it for? what does it mean? and why your video doesn't need this option?
before changing that, i tried divx player, jetaudio and media player classic and got the same result (didn't solve the problem).Last edited by hamidi2; 6th Nov 2015 at 16:53.
The dynamic range setting controls whether the video YUV [16-235] range is expanded to the monitor's RGB [0-255] range when the graphics card is doing the conversion.
Nokia Lumia OIS Jello / wobble due to motor vibration
By Mr. Aldi in forum RestorationReplies: 5Last Post: 22nd Mar 2015, 12:01 -
Vibration causing images to go wierd
By woodlander in forum Capturing and VCRReplies: 11Last Post: 8th Jul 2012, 10:22 -
Recording voice calls how to eliminate echo
By planetx in forum AudioReplies: 12Last Post: 25th Mar 2011, 07:41 -
Decrease zoom-in vibration effect
By SearchQuality in forum RestorationReplies: 14Last Post: 14th Jan 2011, 11:57 -
eliminate contour outlines?
By spiritgumm in forum RestorationReplies: 0Last Post: 9th Dec 2010, 13:45
