Yeah, it's really weird. The TV was my old Samsung plasma. It's probably 7 years old. I had really strong signal from most NYC channels and then plugged that tuner/receiver in and had trouble receiving certain channels that were perfect before. Luckily, I don't use it a ton so it doesn't matter...but it still sucks.
Results 31 to 34 of 34
Anymore many channels can be broadcast on a single frequency. So when they do that, all the channels have to share the limited bandwith. There's a religious channel nearby that puts 6 SD channels on a single frequency, looks bad but they don't care. My local HD NBC channel went from 15Mbps for the main HD channel to 11MBps for the main HD channel, when 2 SD channels were added on the same frequency.
i curious about that here where l live , i see in one frecuency, 4 channels, 2 1080 i hd channels and 2 sd, usually its only one hd and others sd.
According to wikipedia, after you account for overhead a single frequency can carry ~18.3 Mbit/s of actual video data on the ATSC system. So if you give each 1080i channel 7-8Mbit, and then the remainder to the SD channel it can work but would not be great. They are probably using an adaptive bitrate between all the channels. So the channel with a more demanding content will be allotted more than the other channels, making better use of the limited bandwidth. I've seen this behavior with one of my local stations.
how to view walmart video files
By ethan2 in forum Newbie / General discussionsReplies: 3Last Post: 12th Oct 2015, 11:14 -
Questions about some TVs at Walmart
By jimdagys in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2012, 18:35 -
Question About TIVO DVR Timer Programming
By Frank-0-Video in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 11:39 -
newbie question pioneer dvr-433h hard drive restore?
By isakiel in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Nov 2011, 06:06 -
question about converting dvr-ms to dvd
By maca in forum Video ConversionReplies: 1Last Post: 24th Jul 2011, 16:09
