I have a Panasonic camcorder - with a built in HD and sd card slot. It is model SDR-H40P. It has a USB port and another one that says AV. It is half a circle and is a little bit less than 1/4" Can anyone tell me what this is? I am trying to connect this to my computer so that I can capture the video on the computer. I am guessing that this unknown cable - if it can be connected to the computer - would be faster at pushing video through to the computer than the USB port.
Any ideas?
Half a circle? Never seen that. AV ports on camcorders usually use a cable like this:
http://www.amazon.com/gp/product/B00DLLU7QW
What's the model number? -
I looked at accessories for the camera here. This appears to be your camera's AV cable http://www.mcmelectronics.com/product/P-K2KZ9CB00002
The AV cable allows displaying the video on a TV. You would need a SD video capture device and capture software to connect the with a PC. It would probably be better and faster to transfer the files containing your recordings via the USB cable. -
It looks like unusually_quite is right. I missed the model number in the original post. I doubt capturing analog video will be faster than USB transfer if you have a USB 2.0 or better port on your PC. Analog capture will be real time only -- ie, 1 hour of video will take 1 hour to capture.
You would need to try using the Windows file transfer software supplied with the camera to find out.
If you transfer the file from the camera you will have an exact copy of the original recording made by the camera. Capturing the video and audio using the camera's S-Video or composite connection will provide a lower quality copy.
HDMI to S-Video cable or SCART to S-Video cable.Which is better for elgato?
By VideoFanatic in forum Capturing and VCRReplies: 22Last Post: 23rd Jan 2023, 14:40 -
Capturing cable TV: are sources equivalent (cable box vs M-card tuner)?
By Nickster in forum Capturing and VCRReplies: 5Last Post: 12th Oct 2014, 17:45 -
No audio on one SCART cable,another cable is fine?
By SkC1998 in forum Newbie / General discussionsReplies: 25Last Post: 15th Feb 2014, 12:58 -
Help me indentify cable needed. Sold a faulty cable with PVR2
By exbngr in forum EditingReplies: 29Last Post: 12th Dec 2012, 02:17 -
A/V cable & composite cable
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2011, 13:12
