Hi Everyone,
So grateful for this forum!
I am trying to install Pinnacle 19 64Bit on my computer. The installer loads and it completes installation up to 100% and then it gets stuck. I waited 30 minutes for something to happen after it reached 100% but nothing happened. Any ideas and thoughts on what I can do? The program is not installing.
I have used other versions of Pinnacle 14, 16, 17, on the same computer. They are all already installed.
Any information and/or guidance would be greatly appreciated.
Thanks!
Dmitry
If you haven't tried already, ask in the Pinnacle Systems forum. You are likely to get the help you need.
http://forums.pinnaclesys.com/forums/242/ShowForum.aspx
Brainiac
Pinnacle 14 & Pinnacle 17 Poor Video Quality
By kogandmi in forum Software PlayingReplies: 6Last Post: 30th Jun 2015, 03:15 -
Pinnacle Studio AV/DV vs Pinnacle DC 30 for VHS Capture
By Quadzilla in forum Capturing and VCRReplies: 3Last Post: 29th Apr 2014, 00:45 -
installation error
By WarM_FusioN in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 16th Feb 2013, 08:58 -
RipBot264 Installation
By edsmith77 in forum Video ConversionReplies: 3Last Post: 9th Jun 2011, 07:22 -
installation has used too much memory
By alfie64 in forum ComputerReplies: 6Last Post: 16th Nov 2010, 23:39
