Results 1 to 23 of 23
  1. What is the flag to save rtmp mp4 streams as mp4 files, using youtube-dl & rtmpdump ?
    I'm using the -o flag with rtmpdump to save the file as a FLV, but I want to save as a MP4 instead; not sure whether I must do it in youtube-dl or rtmpdump, considering youtube-dl gets the stream, my assumption is rtmpdump ?
    Feb 2008
    You would need to use ffmpeg to mux the flv to mp4.
  3. youtube-dl can't strictly get the MP4 file, even if the actual file online is a MP4 ?
    Feb 2008
    youtube-dl video-url --list-formats
    Note the format code of the mp4.
    youtube-dl video-url -F # -o video.mp4
    or
    youtube-dl video-url -f '(mp4)[height=resolution]' -o video.mp4
    where resolution is 480, 720, 1080, etc...
  5. There are no MP4 format videos, only FLV, can I encode from FLV to MP4 using rtmpdump ?
    Feb 2008
    rtmpdump is only a stream ripper, it does not encode or remux. You will need to use ffmpeg as I mentioned above.
    This is the general ffmpeg command line you would use.
    It will remux the flv container to a mp4 container.
    Video and audio will be stream copied and not re-encoded.
    ffmpeg -i video.flv -c:v copy -c:a copy video.mp4
  7. Originally Posted by Vidd View Post
    That command produces a; Output file #0 does not contain any stream error ?
    Feb 2008
    What is the video and audio codec of the flv? It may be codec that ffmpeg can't put in a mp4 container such as VP6.
    In that case remove the copy commands and instead have ffmpeg encode h264 video and aac audio.
    Something like:
    -codec:v libx264
    -codec:a libfdk_aac
    In the ffmpeg documentation you can find the other switches for profiles/bit rate/ etc.....
    https://trac.ffmpeg.org/wiki/Encode/H.264
    https://trac.ffmpeg.org/wiki/Encode/AAC
  9. I don't know the video and audio codec of the file.
    ffmpeg 19-Octvideo.flv -codec:v libx264 -codec:a libfdk_aac videotyrr.mp4
    Error: Output file #0 does not contain any stream ?
    Feb 2008
    Are you putting the input switch -i before 19-Octvideo.flv?
    -i 19-Octvideo.flv
    But since ffmpeg is giving you problems, another option is to use AviDemux to convert the flv to mp4 instead of ffmpeg.
  11. Adding the -i flag produces a new error; Unknown encoder 'libfdk_aac' ?
    I'm trying mp2 audio codec, as that codec didn't fire any errors.
  12. works for me
    latest ffmpeg 2.8.1
    you must tell ffmpeg the path and filename
    input.flv is in C:\
    then put your audio and video options "-acodec libmp3lame -ar 48000 -vcodec libx264"
    then save to C:\
    as output.mp4
    easy
    ffmpeg -i c:\input.flv -acodec libmp3lame -ar 48000 -vcodec libx264 c:\output.mp4
  13. This worked; ffmpeg -i 19-Oct.flv -codec:v libx264 -codec:a mp2 videotyrr.mp4
    This didn't; ffmpeg -i c:\input.flv -acodec libmp3lame -ar 44100 -vcodec libx264 c:\output.mp4 - let me upgrade ffmpeg
  14. Audio & Video at both MP4 worked out successfully; considering I don't know any information of the FLV file to which I am encoding.
    I'd prefer to play around with various encoding formats; not knowing I will benefit from what is working, it's worth a try
  15. you must be using
    1920's ffmpeg lol
    use the latest
    you can find info of the flv with vlc
    Tools > Codec information > codec tab
    tells you what audio and video codecs are in that file
    cant see how you coverted a file with ffmpeg
    when you did not tell ffmpeg where the input file was ?
  16. The format of the video must be MP4, the audio for the video file can depend.
    The input file and output file were both in the same folder.
    I'm going to upgrade ffmpeg and update my results.
  17. Originally Posted by PowerFalcon View Post
  18. In other words, I must decode the FLV to strictly MP4 video, but the audio of the FLV file can be encoded to any format, so long as there isn't a second delay in the audio or it sounds horrible.
  19. your device only play mp4 then
    no mkv, avi, vob flv
    lol
  20. I prefer MP4, my device plays FLV (not all) as well as h.264 & mkv.
  21. you have enigma2 sat receiver ?
  22. No, Roku2!
  23. The FLV files are AVC1 (h264) and Audio is AAC, from what I find about the file info.
