Does Multithreading in Avisynth can cause quality loosses, or improvements?
Is it difference from filter to filter, function to function?
Is there ways to know quality differences, or measure them?
No difference in quality. Though there can be issues with out-of-order frames with some source filters. You could use MSU VQM Tool to compare two videos. The usual problems with multithreading are running out of memory and crashing.
There are several known multi-threading capable plugins and others which are known to have issues in multi-threaded usage cases because their programming style is not "re-entrant" (cannot easily work in several parallel instances).
AviSynth+ has a per-plugin system to justify the optimal MT mode and maintains an online document as import scriptlet with current recommendations. This may also be a good source to know which plugins to avoid in AviSynth too (functions in MT_SERIALIZED mode will fail when executed multi-threaded, from video corruption to crashes). -
Thanks guys.
I do not have MSU VQM Tool.
The free version let not handle 720p
Any other way to calculate quality of 2 or more videos? -
You can use AviSynth functions Compare for PSNR, or SSIM for SSIM metric, writing out log files which can be analyzed in a spreadsheet calculator (e.g. Excel). Just run an analyzing scipt (comparing two input clips) through AVSMeter once. Important: To actually output the log files, the output video clip of these functions must be part of the final video output of the script (if not, AviSynth may optimize the function call out completely), so if you want to run both Compare and SSIM on the same two input clips, combine both their outputs e.g. using Merge.
The compare.log file may have to be loaded differently into a spreadsheet, I don't know its format right now without trying...Code:c1 = LwLibavVideoSource("clip1") c2 = LwLibavVideoSource("clip2") Merge(Compare(c1, c2, "", "compare.log"), SSIM(c1, c2, "ssim.csv", "avgssim.txt", lumimask=true))
Another free comparison tool is Fritz Framalyzer.Last edited by LigH.de; 19th Oct 2015 at 02:02.
I didn't know AviSynth had that feature. Thanks.
One can also use Subtract(). That shows the difference between the two images. You can follow that with Levels(120,1,135,0,255) to make the differences stand out more. This is a purely visible test. No stats. Or you can follow Subtract() with ColorYUV(analyze=true) to get some numeric stats about the differences.Last edited by jagabo; 19th Oct 2015 at 07:40.
Can MCTD & QTGMC be run on a 16 Core CPU in non-MultiThreaded?
By MrBiggles in forum RestorationReplies: 17Last Post: 23rd Feb 2017, 12:19 -
AVISynth script exact effects to apply in Premiere Pro. need help plsss
By asim in forum EditingReplies: 6Last Post: 2nd Nov 2014, 06:07 -
TAudioConverter 0.9.5-Multithreaded Audio Converter-Extractor CD ripper
By ozok in forum AudioReplies: 69Last Post: 23rd Jul 2014, 23:26 -
TEncoder 4.0.0 - Multithreaded GUI for FFMpeg and Mencoder (Support thread)
By ozok in forum Video ConversionReplies: 104Last Post: 4th Jun 2014, 10:10 -
Convert MKV w/ .ass subs & effects to MP4. Sub effects won't stick. Mac.
By nobodyhome in forum Video ConversionReplies: 4Last Post: 2nd May 2013, 14:38
