hi, i tried my first encode in VirutalDub, (1080p mkv to avi) i created an avs script in megui then opened it in vdub, also downloaded ffmpeg plugin, so i set the 1st pass added it to queue and then the 2nd pass also added it to queue. Then i started the encode. The only problem is that vdub encodes with 3-4 fps which is horribly slow, so i want to ask is it normal? In megui i got 40-50 fps for the same file.
thanks
Shouldn't be that much of a difference
What else , what other operations are you doing in vdub ?
Are you using the same or very similar encoding settings ?
You don't need the ffmpeg plugin to open avs scripts in vdub - in fact it causes problems with avs scripts unless you open them with the AVI driver -
There can be a 100 fold difference in encoding speed with different encoder settings. If you don't use the same settings you shouldn't expect the same speed.
i just resized the video to 720x304, and left all setting by default
VirtualDub very slow in WIndows 7 32bit
By vonsworld in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2015, 08:37 -
Fix mp4 fps without re-encoding?
By TubeBar in forum Video ConversionReplies: 6Last Post: 6th Apr 2015, 10:25 -
Why VirtualDubMOD is slow and VirtualDub is fast?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2014, 08:44 -
FPS changing while encoding in Megui
By jonnydavala in forum Video ConversionReplies: 7Last Post: 19th Mar 2014, 05:50 -
VirtualDub problem: it's slow with karaoke encoding... Why?!
By matsujunna in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2011, 00:34
