I have tried 2 free programs Recuva & wise data recovery, both don't show up anything when scanning the disc like I normally would my C: It just says 0 files found.
Not sure what this means & how to get the files? Maybe need to connect through sata on mobo?
thanks
Get the drive OUT of the rinky-dink, oddball, cheap-crab USB work-around enclosure and connect it directly to the mobo with nothing else in between, as a secondary drive.
NEVER, EVER attempt any diagnostics or low-level repair on a hard drive connected in ANY non-standard way. First, the enclosure is most likely to be the problem and second, they use various methods to not report accurately on precise head, sector, and cylinder information to the mobo hardware and OS, such information is MANDATORY for most recovery and repair programs.
GetDataBack is the best I have ever used, hands down, no question. Recuva is decent for free. ALWAYS prefer to recover data to a second data drive, AVOID IF AT ALL POSSIBLE any write operations to the suspect drive until all data is recovered and saved elsewhere. GetDataBack demands this.
Then delete the partition, reboot, recreate partition and do the long format, NOT the quick one. -
Here are detailed steps for you to rescue your contents there:*
1). Do not overwrite this hard drive in case of real data loss problems.
2). Scan it with data recovery software to see whether all of your wanted contents inside this drive could be restored. There are always many data recovery tools online. Just select one for your*hard drive*, like uFlysoft, iCare Data Recovery Free, 4Card Recovery and TestDisk, etc.
3). Save and back up all restored data on a different drive in case of data loss.*
Never forget to make data backup again in the future. -
Old thread, but, if anyone reads this in the future, it should be noted that for some external drives it is MANDATORY to use the “rinky-dink, oddball, cheap-crab USB work-around enclosure”, in cases where, either or both :NEVER, EVER attempt any diagnostics or low-level repair on a hard drive connected in ANY non-standard way. First, the enclosure is most likely to be the problem and second, they use various methods to not report accurately on precise head, sector, and cylinder information to the mobo hardware and OS, such information is MANDATORY for most recovery and repair programs.
– the USB bridge is soldered to the drive's PCB, which doesn't have a standard SATA connector ;
– the drive is encrypted at the USB bridge level.
I used to use GetDataBack and R-Studio, but GDB has stalled while R-Studio has vastly improved. At forum.hddguru.com, the three most recommended data recovery softwares (consumer level to prosumer level, i.e. outside of very expensive professional tools) are R-Studio, DMDE, and UFS Explorer. (I have no experience with the last one.)GetDataBack is the best I have ever used, hands down, no question. Recuva is decent for free.
Recuva hasn't been updated since 2016, but is still very efficient for a free program, sometimes even outperforming R-Studio in specific areas. (More details here.)
I don't know what this was supposed to accomplish, if the purpose was to recover files...Then delete the partition, reboot, recreate partition and do the long format, NOT the quick one.
There are many, but few actually good ones.There are always many data recovery tools online. Just select one for your*hard drive*, like uFlysoft, iCare Data Recovery Free, 4Card Recovery and TestDisk, etc.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Feb 2025, 02:20 -
Data recovery options for reformatted sd and cf cards?
By Garlic in forum RestorationReplies: 12Last Post: 13th Feb 2019, 00:47 -
Best way to transfer data between two computers? usb cable or usb hdd?
By yoda313 in forum ComputerReplies: 19Last Post: 9th Feb 2014, 09:45 -
Securely Erasing Data On an External HDD
By TheShortStraw in forum Media Center PC / MediaCentersReplies: 4Last Post: 10th Nov 2013, 10:35 -
External HDD with USB 3.0 - problems connecting
By alintatoc in forum ComputerReplies: 10Last Post: 14th Apr 2012, 13:04
