Results 1 to 15 of 15
    The Netherlands
    Hi everybody,
    I have an mp4 file with closed captions and want to extract the subtitle srt. I tried it with CCextractor, but the software says "Failed to open mp4".
    What can I do?
    I used the original settings of the software, but also tried with mp4 selected. Is there anything else I can do?
    Or other software I could use?
    Thanks.
    Can you post the details from the mp4. Use mediainfo, open mp4, view->text and copy everything.
    Have you tried mp4box or a gui like mymp4boxgui and see if it finds any subtitle track in the mp4?
    The Netherlands
    Formaat : MPEG-4
    Formaatprofiel : Base Media / Version 2
    Codec-ID : mp42
    Bestandsgrootte : 201 MiB
    Duur : 46mn 50s
    Totale bitratemodus : Variabel
    Totale bitrate : 599 Kbps
    Datum codering : UTC 2036-02-06 06:28:16
    Tagdatum : UTC 2036-02-06 06:28:16
    Gebruikt programma : HandBrake 0.10.2 2015060900
    Video
    Formaat : AVC
    Formaat/Info : Advanced Video Codec
    Formaatprofiel : High@L3
    Formaatinstellingen, CABAC : Ja
    Formaatinstellingen, ReFrames : 5 frames
    Codec-ID : avc1
    Codec-ID/Info : Advanced Video Coding
    Duur : 46mn 50s
    Bitrate : 401 Kbps
    Breedte : 720 pixels
    Hoogte : 416 pixels
    Beeldverhouding : 1,731
    Frameratemodus : Constant
    Framerate : 25,000 fps
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    Scansoort : Progressief
    Bits/(Pixel*Frame) : 0.054
    Stroomgrootte : 134 MiB (67%)
    Gebruikte encoderbibliotheek : x264 core 142 r2479 dd79a61
    Instellingen codering : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    colour_range : Limited
    colour_primaries : BT.601 PAL
    transfer_characteristics : BT.709
    matrix_coefficients : BT.601
    Audio
    Formaat : AAC
    Formaat/Info : Advanced Audio Codec
    Formaatprofiel : LC
    Codec-ID : 40
    Duur : 46mn 50s
    Bitrate-modus : Variabel
    Bitrate : 192 Kbps
    Kanaal(en) : 2 kanalen
    Kanaalposities : Front: L R
    Samplerate : 48,0 KHz
    Stroomgrootte : 64,5 MiB (32%)
    Titel : Stereo / Stereo
    And MP4 Box only finds a AAC audio besides the video of course.
    Try remux the mp4 with mymp4boxgui (or from mp4box command line). Add the mp4 and make a new mp4. Open in ccextractor.
    Or try extract the video track with mp4box to a m4v and open in ccextractor.
    The Netherlands
    There is only the Mux and Demux option in Mp4 Box. No Remux option.
    When I extract the videotrack and open it in CCextractor I get this
    Incomplete box gd..failed to open
    The Netherlands
    Ok got that. But now CCextractor says
    Analyzing data with GPAC (MP4 library)
    opening : ok
    Track 1, type=vide subtype=avc1
    Track 2, type=soun subtype=MPEG
    mp4: found 2 tracks: 1 avc and 0 cc
    closing media: ok
    Found 1 AVC track(s). found no dedicated CC track(s).
    The Netherlands
    BTW if somebody wants to give it a try, here is the file http://we.tl/itcC7gNzRm
    But let us know what you did, so that we can do it ourselves too.
    Sep 2012
    Australia
    There are no captions in there.
    Handbrake can't transfer captions into an mp4 as an actual CC track, it either burns them in or converts them to ordinary subtitles.
    The Netherlands
    So what are you saying? The audio of this video can't be extracted to an srt file? I don't believe that. There must be an option.
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope. The audio can't be extracted to srt....only closed captions...
    The Netherlands
    Well it must be possible. because somebody else has the srt file, but he is asking 20 dollars for it.
    I am not 100% sure, but I think he got it from the videofile.
    Sep 2012
    Australia
    Do you mean that particular file made by handbrake?
    If he's asking $20 for it, is it possible he made the subtitles himself by ear?
    The Netherlands
    I mean the subtitles for the video I try to get subtitles for in this thread. Yes it is possible he made them himself, but I don't think so.
    BTW you are from Australia. Can I contact you? I tried to send you a pm, but I think you haven't enabled that.
    Sep 2012
    Australia
    http://uksubtitles.ru/subtitles-for-3-episode-series-3-a-place-to-call-home-s03e03-som...e-sea-soho-au/
    https://en.wikipedia.org/wiki/List_of_A_Place_to_Call_Home_episodes
    A Place to Call Home - 03x03 - Somewhere Beyond the Sea
    The other possibility is that he captured the digital captions from the broadcast transport streams. If you have one of THOSE we might be able to help, otherwise Subtitle Edit and some of your spare time is your best option.
    The Netherlands
    The first link is the one in which he asks for 20 dollars. After you have paid, he will send you the srt file.
    And no I don't have the transport streams. And I don't think he has those either. He isn't from Australia and Foxtel-Soho is pay tv.
