Laptop running Windows 8.1
Latest version of HandBrake
HandBrake sees and recognizes everything about the VIDEO_TS folder(including chapters).
HandBrake finishes but with only around 35 minutes in the resulting MP4 file(using High Profile setting).
Happens on both de-encrypted DVDs(ripped with AnyDVD first) and most recently with a homemade DVD with the
VIDEO_TS folder copied and pasted to the laptop HDD....both encodes failed at about the same time/duration.
HOWEVER...when I ripped a disc to a VIDEO_TS folder on my PC with DVDFabDecrypter, then gave that VIDEO_TS
folder to my wife to convert with HandBrake....it encoded perfectly on the laptop.
I hate laptops because their burners have such shitty reputations for longevity. Could this be a DVD drive/burner problem?
I don't think she has updated AnyDVD for a while....I haven't either now that I think about it.
AND my version of DVDFab is OLD....
Any suggestions aside from getting her her own install of DVDFab and/or updating AnyDVD? The VIDEO_TS folders are fine.
If you were only having failures straight from the optical drive, I might suspect the burner to be part of the problem, but you also seem to have an example of an unencrypted DVD-video failing to encode properly from the hard drive as well.
Is the laptop overheating while encoding?
Just as an experiment, I might update AnyDVD to the latest version, rip a DVD to the hard drive and encode it from there, first with Handbrake, then with something else, perhaps VidCoder or Ripbot264.
Not sure what to do? VIDEO_TS folder to ISO?
By niteghost in forum Video ConversionReplies: 5Last Post: 21st Jul 2014, 11:51 -
I'm trying to encode a VIDEO_TS with Handbrake but it does not stop.
By Tetsuro in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2014, 17:00 -
any way to add (or change) chapter stops with a Video_TS folder?
By amckinney in forum MacReplies: 4Last Post: 19th Sep 2013, 14:22 -
VIDEO_TS folder on harddrive?
By BaaGGHo in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2013, 00:40 -
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 16:00
