Searching the internet and this forums did not result in a solution, so I start a new thread.
I am using a simple avs script to open a mov-container with Cineform video rendered with Premiere Pro/ME CC14 and rendering it in command line with x264. Normally I just use
Because of this thread I wanted to try ffms2 to be able to import 10bit intermediates to reduce banding, which is a huge problem in my footage.Code:QTInput("x:\intermediate_cineform.mov", mode = 4) ConvertToYV12()
With ffms2 in Avisynth 2.6 or the downloaded version ffms2-mt-r375 I get "Codec not found" errors.Code:LoadPlugin("C:\Program Files (x86)\AviSynth 2.6\plugins\ffms2.dll") FFvideosource("x:\intermediate_cineform.mov", enable10bithack=true) f3kdb_dither() ConvertToYV12()
With these ffms2 versions
http://avisynth.nl/index.php/High_bit-depth_Support_with_Avisynth
ffms2-6e0d654+a9fe004-ffmbc-FFmbc-0.7.1.7z
ffms2-6e0d654+a9fe004-ffmpeg-1e4d049.7z
that error does not occur, but after indexing I always get:
So I would like to import the 10bit Cineform intermediate in 10bit (not converted to 8bit), dither (hope this helps against banding) and then encode in x264 in 8bit for further use, eg. ppload to Vimeo.avs [error] FFVideoSource: No video track found
What am I doing wrong, please? Any help for this dummy setup is appreciated.
AFAIK ffmpeg does not support cineform decoding so using ffms2 is futile.
But there seems to be a method for VapourSynth using the original codec:
http://forum.doom9.org/showthread.php?p=1682988#post1682988
QTinput also has a "dither" parameter, maybe that's sufficient for you? (I have no idea if it works or what method it uses) -
Hi sneaker,
thanks a lot for the hint with VapourSnyth! I will try that. Any idea how to rewrap mov into avi without any hassle? Never did that, will have to search.
QTInput has a dither command, but it doesn't work for me. Manual insists on mode=1 and raw="v210":
But that gives me an error:mode - Decode mode (default = 0)
0 = Uses Quicktime SDK function MoviesTask to decode video.
1 = If source file is one of several YUV formats (listed below), this mode returns raw data.
2 = Uses Quicktime SDK function DecompressSequence to decode video.
Should probably not be used for mpeg4 (h263, h264, etc.), try mode=0 or mode=3 instead
3 = Uses Quicktime SDK function ICMDecompress to decode video.
4 = Uses Video for windows codec.
raw - raw input colorspace (default = "yuyv")
If mode = 1, this sets the input file colorspace method. Choices are:
uyvy (2vuy), yuyv (yuy2), yvyu, vyuy, yuv2 or v210 (10bit uyvy), rgb, argb.
dither - raw 10bit to 8bit dither mode (default = 0)
0 = off
1 = Uses the 2 least significant bits as a fraction for rounding the 10bit value to the nearest 8bit value.
Currently this really isn't a dither mode, but is in place for a future dither mode option.
This only has an effect when mode=1, raw="v210."
I am afraid, that won't work. dither=1 at mode=4 (which I normally use) has absolutly no effect...Code:avs [error]: Cannot InitializeGraphics: GoPro Cineform Error retrieving uncompressed data. Does not appear to be in V210 format
You can re-wrap cineform MOV => AVI with HDLink, but it was only available on various older paid versions of cineform . They haven't released it as a new utility or a similar utility yet since cineform became the new open VC-5 standard
For vimeo or youtube - It's not going to make much difference starting at 10bit then dithering when converting to 8bit , or starting with 8bit then dithering. The main problem is their re-encoding practices - there just isn't enough bitrate to retain the dither
avisynth 2.6 + ffms2 2.22: why don't open mxf (mpeg2) video files?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 6th Sep 2015, 13:19 -
what is the latest ffms2 for avisynth?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 17th May 2015, 07:43 -
x264 What is the difference using raw input vs. AVS script that uses FFMS2?
By kotuwa in forum Video ConversionReplies: 6Last Post: 6th Nov 2014, 07:58 -
what is the latest ffms2 ffmpeg 32bit plugin for avisynth?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 23rd Aug 2014, 17:11 -
Avisynth/FFMS2 error: video track is unseekable
By marcorocchini in forum Newbie / General discussionsReplies: 97Last Post: 19th May 2014, 08:24
