My friend installed avconv.exe on my computer without knowing it (sigh...) but in fact it's because download helper proposed it.
Is avconv.exe a big of help and useful?
Or is it risked?
I noticed that my computer overheated a little more than usually, thus if it's risked how can I uninstall avconv.exe?
Only positive point for the moment, is that download helper proposes more choices of conversion...
Results 1 to 9 of 9
ok, but did my processor wil not burn because of him?
'cause my computer seems overheated since it was installed
and when you download a ADP video with downloadhelper, did your video is without audio? -
Video conversion / transcoding requires alot of the CPU, thus it gets hot - this is absolutely normal. Why your download / conversion fails, I do not know. You might want to find a way to disable video conversion in downloadhelper if you do not want it.
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
I recommend uninstalling downloadhelper because re-encoding is ABSOLUTELY not required! (you waste time and you get stupid watermark). Try Video Downloader professional plugin instead.
Just go to video downloadhelper settings and remove the converter - problem solved. You do not need to convert downloaded files.
Dailymotion + 'Video DownloadHelper'
By pooksahib in forum Video Streaming DownloadingReplies: 6Last Post: 8th Aug 2015, 16:35 -
subtitle forced flag lost with avconv
By bruchmann in forum Video ConversionReplies: 0Last Post: 13th Feb 2014, 08:18 -
How to use downloadhelper?
By vladorlok in forum Newbie / General discussionsReplies: 3Last Post: 12th Jul 2013, 13:56 -
Avconv Can not resample 6 channels
By Beckend in forum Video ConversionReplies: 4Last Post: 20th May 2013, 21:34 -
Having Trouble Using mkv2vob No matter What I Do I Get Txmuxer.exe Fail
By ITSMEDAVID in forum Authoring (Blu-ray)Replies: 0Last Post: 10th Nov 2011, 22:20
