    Jun 2006
    I have a DVD that I just purchased Duel At Diablo 1966, the box says it's a Widescreen 1.66.1 Theatrical release format. MediaInfo gives me this after using VOB2MPG Pro:
    Complete name : C:\Video\Duel At Diablo.mpg
    Format : MPEG-PS
    File size : 3.43 GiB
    Duration : 1h 44mn
    Overall bit rate : 4 709 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Duration : 1h 44mn
    Bit rate mode : Variable
    Bit rate : 4 423 Kbps
    Maximum bit rate : 8 700 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.427
    Time code of first frame : 01:00:01;15
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    Stream size : 3.23 GiB (94%)
    GOP, Open/Closed of first frame : Closed
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Muxing mode : DVD-Video
    Duration : 1h 44mn
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 143 MiB (4%)
    Text
    ID : 224 (0xE0)-CC3
    Format : EIA-608
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    I would like to convert it to a mp4 with Avanti, not sure about what Frame size or DAR to use. Can someone please give me a helping hand?
    Jul 2014
    Denmark
    MediaInfo says frame rate = 29,97 and DAR = 4:3
    I'm the developer behind FFQueue. My posts might reflect this! ;-)
    Jun 2006
    OK, now what Frame size do I use not Frame rate.
    Jul 2014
    Denmark
    MediaInfo says 720 x 480
  5. Use Handbrake. It will crop the letterbox bars and handle the aspect ratio for you.
    Jun 2006
    Thanks, I will use HandBrake
    What Anamorphic and Modulus settings would you use if you were doing this?
    Jun 2006
  8. Mod 4, anamorphic loose or strict is fine unless your playback device doesn't support anamorphic encoding.
