Is that possible? If possible, what must i do ?
XVCD or VCD --> NO
SVCD --> you can convert the audio to multichannel MPEG audio. This is in the specs but is very poorly supported by hardware and probably won't work for you either. Furthermore, it is a cumbersome set of steps.
Search the forums if you want the information. It's been posted plenty of times.
Regards.
Michael Tam
w: Morsels of Evidence
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 14:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
