Hey there guys i have set up my hd pvr and i have no audio on my tv, but when i record it does grab the audio but not on the tv, pls help me :P
Anonymous188Guest
Do you mean that there is no audio on the TV when using the original HD-PVR's component video passthrough? ...or are you actually using the HD-PVR 2 and its HDMI out is connected to the TV?
Anonymous188Guest
If you are using Hauppauge Capture, there is a problem with no audio when using older versions of that software with the HD-PVR 2 Gaming Edition. That problem is supposed to be fixed with the newest version of Hauppauge Capture. You can download Hauppauge Capture version 33251 from http://www.hauppauge.com/site/support/support_hdpvr2.html
Anonymous188Guest
I remembered seeing something about Hauppauge Capture causing a loss of audio in the HDMI-output from the Gaming Edition model, so I hoped that updating the software and drivers would be enough.
If you have an HDMI splitter, you could connect the TV to one of the splitter's outgoing connections and avoid using the HD-PVR 2's HDMI out. If you need a splitter, I bought this to use with the original Colossus, which has no HDMI out. It removes HDCP as a side effect.
Beyond that, I can't offer you much help since I don't have an HD-PVR 2.
SageTV Works With Hd pvr 2 Gaming Edition?
By Shlomi in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2014, 13:24 -
PVR Gaming Edition 2
By muncher in forum Latest Video NewsReplies: 5Last Post: 25th Oct 2013, 19:53 -
Issue with Hauppauge HD PVR 2 Gaming Edition
By FilmNerd4 in forum Capturing and VCRReplies: 1Last Post: 16th Oct 2013, 18:39 -
Most optimal way to record with the PVR 2 Gaming edition?
By Jonz in forum Capturing and VCRReplies: 33Last Post: 1st Aug 2013, 00:42 -
Hauppauge HD PVR 2 Gaming Edition: "The device is not available"
By Justinrp in forum Capturing and VCRReplies: 7Last Post: 26th Apr 2013, 11:20
