I have Toshiba SD2800 DVD player and it says it can play DVD,VCD and CD disks but when I trying to play CD-R then it doesn't recognize that CD. Did anyone know why ? and what kind/name of the CD-R should I use to play on my DVD player.
Any help is appreciated.
-Shailendra.
only time I had that happen is it is not vcd compliant, try another dvd player like apex, if it works then it is the dvd player. When I buy I take one of my vcd's to the store with me to try on the demo model
check in here and see what type of disc is compatible with ure player. http://www.vcdhelp.com/dvdplayers.php
Hi, I have used both XatShow and Nero 5.5 to burn Jpegs into a
format that is readable by my Toshiba SD2800. I followed the directions
to a "T" and was able to get the burned CD-R to work in my PC, but
not on my DVD. Actually I have 2 DVDs, my Toshiba and my
Apex AD-1200. I have burned an AVI file to an SVideo and it worked on the Apex. but, neither DVD player recognizes the CD-R. What could
I be doing wrong?
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
