Sp I got the Extreme7+ and a Samsung EVO 850 SSD.
I can't install Windows 7 x64. It simply refuses to format the drive.
I keep getting 0x80070057.
Results 61 to 68 of 68
I have no idea why win 7 won't format the drive, and i figure you are referring to the formatting stage during the installation.
Have you got an external Hdd caddy, one of those small boxes that you can slip your Hdd or SSD into and power it up connected to your computer via USB cable.
If you have, then you can put the SSD into the dock, let windows detect it, go to Disk manager, and click on that drive, and format it to NTFS and just give it a name (i title mine Win 7) and when its done, put that SSD back into the machine you are installing onto, and when you get to the part to select the drive to install onto, you just highlite that drive and click NEXT, and win 7 should just start installing to that drive, because it will already know it has been pre-formatted.
Just for the record, the reason why i always pre-format every Hdd that i install windows onto is because windows will then not create that 100mb System partition on the HDD, if you put in a new Hdd that has not bee formatted, windows will create that small System partition automatically.
Windows 10 will actually create a 500mb System partition on a new Hdd that has not been pre-formatted prior to a custom/clean installation, not sure why it is so big, but anyway.
Give it a try, see how it goes. -
I tried the bad SATA cable issue. That wasn't it. Or so I thought...
I replaced it again. Now it's fine.
I've never seen a bad SATA cable before! I'm thinking SSD drives are just really picky.
Windows 7 installed fine, and I'm now setting everything up. It'll probably take me another week!
Thanks guys! (gals?)Want my help? Ask here! (not via PM!)
Just as an update, this is running smoothly.
It has a pair of 4tb Seagate, with APM set to performance with CrystalDiskMark. The main SSD is for OS and encoding temp/scratch space.
Old Avisynth projects that were 1-3fps are now 7-10fps, and remember that fps is base 60 math (time), it's about 5-6 times faster, which is what I originally calculated. Overnight encodes are now day tasks.
This was primarily for encoding and restoration, with some need for FFT image filtering, and it seems to be quite nice now.
It is extremely, extremely quiet. The loudest items are the hard drives. I'm still working on the best APM settings, and the best suspend settings for when the drives are idle.Want my help? Ask here! (not via PM!)
Good to know that you are happy with your new system
Glad we were able to help
I would like to build new computer for work to do video encoding
By MGadAllah in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Aug 2015, 11:32 -
Connect compressed MKV parts without re encoding ?
By gil900 in forum EditingReplies: 3Last Post: 18th Feb 2013, 23:58 -
Building a new computer and need some advice.
By ingeborgdot in forum Media Center PC / MediaCentersReplies: 79Last Post: 11th Dec 2011, 12:00 -
Ideas or tips for building computer (mostly for video editing/encoding)
By robjv1 in forum ComputerReplies: 13Last Post: 14th Jun 2011, 14:21 -
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 10:37
