I'm using a macbook pro and wanted to know what’s the best software for re-encoding videos at the best quality with the smallest file output size? I’ve tried Xilisoft, Wondershare etc and such, but they don’t cut it for me.
You didn't actually convert the dvd video to anything when you used makemkv. It just takes the existing video and audio streams and repackages them in a .mkv container. A file extension doesn't tell you what format or codec video there is.
I think handbrake is the best option as well, it has a very good balance of power and ease of use. It ain't a one click program but those options are where the quality is. It's very well documented too, which is why I would recommend it (and avidemux).
If you really want video quality and ease of use, though, the best thing is probably still Makemkv and more hard drives. A lot of people who try encoding may find it's not worth the time to learn it for them. There's a limit to how much I want to get into it.
VHS > Macbook Pro archiving questions
By Morpheuslaughing in forum MacReplies: 12Last Post: 17th Aug 2014, 12:25 -
Which software to control which videofile will be played on my macbook pro
By caslie in forum MacReplies: 1Last Post: 25th Feb 2013, 15:55 -
Laptop Stand for Macbook Pro
By Sakuya in forum ComputerReplies: 1Last Post: 8th Nov 2011, 11:19 -
Is the new Macbook Pro 13" any good for video editing?
By shaharamit in forum MacReplies: 5Last Post: 25th Oct 2011, 11:19 -
CX550v video upload to Macbook Pro
By CameramanBunk in forum MacReplies: 2Last Post: 16th Feb 2011, 19:55
