I have a MKV file which can be played (in VLC) but seems to be not fully correct.
Example:
When I start to do some conversions for a video file and ffmpeg.exe a got an error:
[avi @ 00000000026a0520] H.264 bitstream malformed, no startcode found, use the video bitstream filter 'h264_mp4toannexb' to fix it ('-bsf:v h264_mp4t
av_interleaved_write_frame(): Invalid data found when processing input
I don't want to fiddle around with some parameters.
I want a simple solution.
So is there a "one-size-fits-all" solution
e.g. something like
ffmpeg.exe -checkandrepair -in=myvideo.mkv -out=myvideoout.mkv
Nope,just use the gui.
I wanted to just say thank you. OBS crashed on me at the very end of a recording.
The file "played back" fine but showed an "unknown length" in windows and wondershare could only see the first 12 minutes.
I ran the file through the tool you linked (mkntoolnix) did nothing to change anything I just added it and it "fixed" the file. windows and more importantly wondershare could see the entire 39minutes instead of just the first 12 minutes.
I really did not want to rerecord all of that so thank you
Thank you
MP4 repair (AAC audio repair)
By holger123 in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2020, 18:47 -
audio tracks switched in MKV video: How to repair without re-encoding?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2015, 03:13 -
Repair audio in an MKV
By loninappleton in forum Video ConversionReplies: 1Last Post: 4th Jul 2014, 20:29 -
Ts and Mkv files - bad frames - repair help?
By ttepper27 in forum EditingReplies: 0Last Post: 3rd Apr 2013, 04:08 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
