Has FIOS changed their system or has someone turned the wrong switch. I can't record anything, its all got copyguard my recorder won't work. If anyone
knows any thing I would appreciate a reply. .I then would be looking for device. ????? BILL
What are your using to record these channels? DVD recorder, VCR, or something else?
Can you record local over-the-air broadcast TV channels carried by FIOS? Is it literally every cable channel or just some of them (and what are they)?
The only recent change I have heard of is that Fox asked Verizon FIOS (and others) to enable copy-once protection for the channels they own. Are you having trouble with anything other than FX, FS1, FS2, BTN, FBN, Fox News, NatGeo, NatGeoWild, FXX, FXM, FCSA, FCSC, FCSP, FX HD, FS1 HD, BTN HD, FBN HD, Fox News HD, NatGeo HD, NatGeoWild HD, FXX HD? -
I have 2 hard drive recorders which I use at various times. Went to record a show so I could fast foward thru the commercials. My recorder displayed cant recorded protected material. Same on the other machine. Won't record broadcast stations. ??????Thanks for your reply
By "HDD Recorders" I assume you mean you are using DVD recorders with a hard drive. If not, please provide the make and model of whatever other device this is.
If you have HDD DVD recorders are you using one of its an analog video connection to record rather than the tuners? If so, then you need a device that removes the copy protection flags from composite and S-video. One member here recommends the Dimax Grex for this purpose.Last edited by usually_quiet; 10th Oct 2015 at 20:56. Reason: typo
Curious about this as well since I have FIOS but when I external record to a dvd recroder have not run into any issue yet. Could you provide what channel(s) gave you the problem? I can try it out here and let you know
I have finally resolved the issue, broke out my old decoder and this works good on my magnovox hard drive recorder, but I had to buy the Grex decoder and it works fine on my pioneer hard drive recorder. Of course it don,t record in HD.i record it in SD and the blacked out portions on top and bottom aren,t bad. Picture doesn't,t look distorted.
Questions about FIOS Quantum
By Bigbill in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2014, 13:55 -
Hooking up my PC monitor to my FIOS STB and XBOX 360
By pbdeberry in forum DVB / IPTVReplies: 1Last Post: 14th Dec 2012, 14:01 -
what is the best way to capture broadcast shows from verizon FIOS....
By unclescoob in forum Capturing and VCRReplies: 15Last Post: 12th Oct 2012, 13:13 -
Where do you get your news from?
By johns0 in forum PollsReplies: 20Last Post: 14th Mar 2011, 21:38 -
Panasonic Viera with Dynex DVD and FIOS Remote question
By zumata in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Feb 2011, 14:23
