Hi, I have a few questions
Firstly, i've been trying to hardcode some subtitles (srt) to an mpg file. I've used Handbrake and the subtitles are burnt onto the image fine and at the right time, except that there is a character ( á ) that doesn't show up and instead shows up as á (the rest of the subs are in English). The subs are saved as UTF-8 and when I loaded them before as an external subs file the character appeared as it should. Should I be saving this as a different filetype or be entering a different character(s) in place of á?
Secondly, the last 4 subtitles have not been burnt onto the output file. I have no idea why, the times are all right and the rest of the subs are at the right times.
Thirdly, is there any way to lose minimal quality on the conversion from mpg to mp4? the mpg file is 314mb and comes out as 76mb in mp4.
Should I not be using Handbrake? If not which is the best to use? VLC hardcoding didn't prove successful, nor avidemux.
Sorry if this is repeating a lot of threads, I've read lots of forums but can't find anything that specifically answers my question
Thanks for any help!
Open the srt with subtitle edit and try the fix common error wizard. See http://www.nikse.dk/SubtitleEdit/Help#fixcommonerrors . Or else try replace the char á with something else...maybe just a'.
You could also try hardcode with xmedia recode and see if it handles utf-8 better. It might be a bit tricky to get it working but check https://forum.videohelp.com/threads/373379-How-to-burn-in-hardcode-srt-with-Xmedia-Recode .
And lower the Constant quality/quantizer value under the video tab for better video quality. Try 15 instead 20. Use the high profile also. In xmedia recode you find the Constanst quality under Video and Rate control mode.
Please help hardcoding .srt subs to MP4 using Vidcoder or else...
By novice121 in forum SubtitleReplies: 7Last Post: 30th Nov 2015, 15:52 -
Hardcoding Subtitles to the Movies
By Smoke n Fly in forum SubtitleReplies: 3Last Post: 3rd Dec 2014, 13:03 -
Trouble Hardcoding SRT Subtitles to MP4 with Handbrake
By Omer Syed in forum Video ConversionReplies: 9Last Post: 30th Dec 2012, 08:03 -
By Omer Syed in forum SubtitleReplies: 1Last Post: 27th Dec 2012, 10:01 -
Backing up with Full HD audio and srt or hardcoding support
By ComptonHPD in forum Newbie / General discussionsReplies: 8Last Post: 20th May 2012, 00:51
