Hello,
I'm seeking to buy a best LNB with best signal... which brand do you advise me to buy?
Results 1 to 16 of 16
http://hypermegasat.com/Dish_LNBs.html
I use a PLL (Phase Lock Loop) LNBs for both Ku and C band and they work very well especially for weaker signals.
Which versions you use depend on your location and setup. Europe is different than US.
The two I use:
Titanium Satellite C1-PLL Phase Lock Loop C-Band LNBF
GEOSATpro SL1Pll Standard Single Phase Lock Loop Ku LNBF -
A LNB can only help so much.
If your location is on the border of the satellite footprint, only a larger dish will help.
Might also help if you stated what satellite(s) you wish to pick up. -
Those two LNBs I mentioned are among the best rated at present.
The PLL setup is a huge improvement and helps keep the LNB locked on the signal.
I use a 3 foot dish for KU and a 4 foot dish for C band. Both have motors.
The 4 footer is too small for good C reception and a 6 foot or larger is usually recommended.
But my subdivision bans larger dishes. -
And I thought my 80 cm dish was big
Still bigger than our standard 60 cm. -
And you would get more help if you answered the questions raised.
I checked these two. Both operate on the Ku Band so that info is essential for picking a LNB
Badr (Arabsat 26E) appears to be picked up in North Africa with a 55 cm dish.
You do have a motorised dish ? If you have a fixed one pointing at some mid point it is understandable why you can not pick these up strongly.
Another issue is if you do not have a clear line of sight to the satellites. Any tall building or other obstruction in the way will degrade the signal. No dish or LNB can help you there.
I can not check Nilesat (7 W) as the footprint is beyond the UK.
Arabsat works fine here with a 80-90 cm dish.
Note: I previously had a 'senior' moment and checked 7 E rather than 7 W. My bad.Last edited by DB83; 14th Oct 2015 at 17:49.
55cm dish in north africa i doubt it (i'd say 80cm minimum)
You can check on kingofsat which dish size you need for Badr (26°East): http://fr.kingofsat.net/beams.php?s=95&b=135*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
My source data:
https://www.satbeams.com/footprints?beam=5320
Just click the location for balloon data.
Ok. I only checked for Tunisia. Other parts of N.Africa such as Egypt have different requirements. -
ASF file not seeking
By Toro567 in forum Video ConversionReplies: 30Last Post: 11th Sep 2015, 09:07 -
POTPLAYER - lag when seeking
By skribby in forum Software PlayingReplies: 9Last Post: 9th Aug 2015, 17:09 -
LG BP330 - Seeking Advice
By THRobinson in forum DVD & Blu-ray PlayersReplies: 15Last Post: 30th Oct 2013, 17:14 -
INTERNET TV ...Seeking Direction?
By RE_MOTE in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2013, 19:25 -
WMV jump seeking
By 1031982 in forum EditingReplies: 0Last Post: 30th Nov 2010, 16:08
