I try mkvextract2 but made file without extension, and if i rename .265, .h265, .yuv dont open in mp4box.
Next i try command in ffmpeg with copy video (no re-encoding) but file dont open in video editor and try Avanti-gui but not start.
Where is the problem? i need open 265 in video editor like sony vegas pro 13 without convert video every time. there is video editor for hevc?
Results 1 to 9 of 9
Vegas doesn't support HEVC. The next update of Premiere Pro is supposed to natively support HEVC
You can use a freeware program aviutl to edit HEVC, but it's not a full featured NLE (but still can do many things, multiple layers, many effects)
Or you can frameserve into any program (including vegas) with avisynth and avisynth virtual frame server -
I need software for open 2 video, find difference (tv cut, opening, ending) sync tv audio on bluray. now i use audacity, but if there are too many difference, i need real time video compare. you know any simple and fast solution with hevc support.
for Vegas I find this HEVC_FileIOPlugin.dll plugin, but dont work with .mkv hevc
edit2: blender open mkv hevc, but i dont know how to useLast edited by gott4; 8th Oct 2015 at 09:48.
The other issue is real time playback might be a problem in a NLE because HEVC is computationally expensive to decode - real time playback within an NLE probably won't be possible without GPU acceleration on typical hardware unless you use lower resolutions (UHD won't decode in real time)
ok, but there is a method for sync audio editor timeline bar with external video player time?
Do you have a link to that Vegas hevc.dll? I'd like to test it out, but I have a feeling it is bogus..
This thread may interest you: https://forum.videohelp.com/threads/368684-Editing-4k-HEVC-footage-(Samsung-NX1)Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
you can download here http://www.videotreffpunkt.com/index.php/Thread/18251-HEVC-ProRes-XAVC-L-Vegas-Plug-In/
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
Samsung TS (HEVC) into MKV
By Camboui in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2014, 13:31 -
How can you import HEVC videos in Adobe Premiere Pro cc? (mkv mp4)
By Stears555 in forum Video ConversionReplies: 2Last Post: 17th Apr 2014, 10:57 -
what are the minimum support files needed for hevc videos to mp4 ?
By vhelp in forum Video ConversionReplies: 2Last Post: 3rd Nov 2013, 13:44 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19
