Hi everybody!
Glad to be here! It's a really nice and interesting forum!
I'm a newbie about video editing and I was wondering if anyone could tell some hints for a conversion work I had to do...
All files have been processed from DVD5/9 to .mkv with MakeMKV.. (v_mpeg2) and now I've to convert them to h264. I'm using xmedia recode and I'd like to know the best settings for the conversion... I'd prefer quality rather than file dimension
Thanks in advance...
Here the media info of the mkv:
Format : Matroska
Format version : Version 2
Duration : 1h 36mn
Overall bit rate : 5 237 Kbps
Encoded date : UTC 2015-10-01 16:51:15
Writing application : MakeMKV v1.9.6 win(x64-release)
Writing library : libmakemkv v1.9.6 (1.3.0/1.4.1) win(x64-release)
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Format settings, picture st : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate mode : Variable
Bit rate : 4 749 Kbps
Maximum bit rate : 8 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Original display aspect rat : 2.40:1
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.458
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 3.19 GiB (91%)
Are you going to edit the video? Then keep them in mpg/mpeg2 and edit it instead of reconverting first. You can try remux the mkv to mpg with xmedia recode (under video choose copy mode and under audio copy). Then import the mpgs in your editor.
Or else use Video->Rate control mode: Constant quality/quantizer encoding mode in Xmedia recode or use Vidcoder(high profile). Use a value around 20 or lower for even better quality(bigger file size).
Hi - A question about XMedia Recode encoding settings.
By Jimbo1 in forum Video ConversionReplies: 7Last Post: 6th Jul 2017, 15:22 -
Xmedia recode settings for Bluray ripping??
By davidh10_99 in forum Blu-ray RippingReplies: 6Last Post: 22nd Apr 2015, 14:31 -
Xmedia Recode - quality settings ?
By Digmen1 in forum Video ConversionReplies: 3Last Post: 6th Feb 2013, 02:46 -
XMedia Recode Profile settings buged, please help!
By ssj3hulk in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2012, 15:21 -
Convert miniDV to h.264 using XMedia Recode. Fast moves are very ugly...
By marqus in forum Video ConversionReplies: 3Last Post: 15th May 2011, 04:53
