I try and load the MP2 file into Tmpegenc and It fails to recoginise the format.
Any ideas why ?
Cheers
Jon
Usually, .mp2 is an mpeg-1, layer-2 sound file. Mpeg-2 is a format that can include video or audio and video together.
If you're on about .MP2 files created by the ATI Radeon card (which is what I guess you're on about) then to open them in TMPG you'll need to use DVD2AVI to create a .d2v file first and then open that instead and it works fine then.
Yes you are correct the file was generated from the ATI Radeon, I have downloaded and run it through DVD2AVI which produces two files one for video and one for audio.
Then I try and combine them I get a resulted MPEG1 file but the audio is out of sync any ideas, so close
Cheers
Jon
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 15:44 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 12:16 -
Demuxed mpeg to mv2,mp2 with command line
By vtr in forum ProgrammingReplies: 4Last Post: 15th Sep 2008, 02:22 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 23:15
