Results 1 to 11 of 11
  1. Are there any programs that will cut videos and subtitles at the same time?
    Like i load an mkv with .ass and cut out 5 minutes in the middle of it and the subtitles also cut out those same 5 minutes staying in sync.
  2. You could make a 2-step cut with MKVMergeGUI.
    Or perhaps AVI-MUX GUI if you're using Windows XP/Vista (never got it to work beyond that)
  3. Last edited by Baldrick; 8th Oct 2015 at 06:21. Reason: Fixed link
  4. from what i remember of using mkvmerge it's not very accurate, it doesn't cut exactly where you tell it to, usually a few seconds before\after.
  5. from what i remember of using mkvmerge it's not very accurate
    It cuts on I-frames which may be 10s apart.
    For frame accuracy maybe SolveigMM Splitter. It states now:
    Supports editing of embedded subtitles for AVI, MKV, WEBM files of formats (NEW feature):
    UTF8
    ASS
    SSA
    GAB2
    (it didn't support editing subtitles when I tried it)
  6. Eh it's not free, and the trial has watermarks.
    and the free version is different.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    No FREE tool can cut exactly....and keep subs.
  8. And it wasn't mentioned that it needs to be free.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    You can try and see if MKV Cutter keeps the subs...note that it's an alpha/beta version.
  10. solveigmm video splitter business did what i want, though its kind of buggy.
    thanks guys.
