Hey,
I've been playing around with capturing DVD compliant MPEG 2 in Catalyst Media Center version 1.0.4210. However, I can't seem to figure out if I'm dropping frames. Does anyone know where this information is reported?
Thanks,
Justin
Not the best software, and I have yet to find such a report.
However, even good capture software, like VirtualDub, especially with VHS, can drop frames - even if the report shows otherwise. So even a clean report shouldn't be your dealsealer.
Assuming the drops are random, the best way to find out is to test this with multiple captures. Try this with a tape, or on a TV channel that repeats something every 10 minutes, or a DvD, or whatnot - as long as it's the same content.
Test it with 3-4 captures of a 30+ minute sample, then compare the streams with multiple instances of them. Do they line up properly frame by frame?I hate VHS. I always did.
Dropped frames
By g_randybrown in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2015, 12:01 -
Thousands of dropped frames!! :O
By ChibiBoi in forum Capturing and VCRReplies: 29Last Post: 4th Feb 2013, 15:40 -
best settings for ATI600USB in Catalyst Media Center
By Blitzkrieg in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2012, 13:43 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31
