Good morning , I have a problem with Crash on open Video Editor Avidemux 2.6.10 on Windows 7 - 64 bit, only occurs for some video MP4 and FLV.
I am using Avidemux because I would cut unnecessary parts of videos and to correct audio / video sync.
On Ubuntu 4.14 I Avidemux version 2.5.4 and here the same videos are worked well but I have problems in output synchronization between audio and video in the second part of the video.
Windows open the file and I see a dialog Avidemux 2.6.10 with the inscription:
Crash
ADM_setCrashHook [libADM_core6.dll]
ADM_backTrack [libADM_core6.dll]
ADM_faad::initFaad(WAVHeader*,unsigned int,unsigned char*)
[libADM_ad_faad.dll]
create [libADM_ad_faad.dll]
getAudioCodec(unsigned int, WAVHeader*,unsigned int,unsigned char*)
[avidemux.exe]
ADM_Composer::addFile(char const*) [avidemux.exe]
A_openAvi(char const*) [avidemux.exe]
ADM_QT4_fileSel::GUI:FileSelRead(char const*,void(*)(char const*))
[avidemux.exe]
HandleAction(Action) [avidemux.exe]
Main Window:: searchFileMenu(QAction*) [avidemux.exe]
QMetaObject::activate(QObject*, int, int, void**) [Qt5Core.dll]
QMenu:: setPlatformMenu(QPlatformMenu*) [Qt5Widgets.dll]
QMenu::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)
[Qt5Widgets.dll]
QAction::activate(QAction::ActionEvent) [Qt5Widgets.dll]
QMenu:: set1con(QIcon const&) [Qt5Widgets.dll]
QMenu::internalDelayedPopup() [Qt5Widgets.dll]
QMenu::mo
An example of an MP4 video that sends Crash Avidemux has these features:
General
Complete name : F:\Video\Video-prova5\151003 Rai 5 e.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 269 MiB
Duration : 19mn 51s
Overall bit rate : 1 892 Kbps
Writing application : Lavf52.91.0
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 19mn 51s
Bit rate mode : Constant
Bit rate : 1 800 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.122
Stream size : 255 MiB (95%)
Tagged date : UTC 2015-10-03 13:41:04
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 19mn 51s
Bit rate mode : Variable
Bit rate : 93.6 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : 40ms
Stream size : 13.3 MiB (5%)
Language : English
attached file : admlog.txt
thank you
Results 1 to 1 of 1
AVI files won't open in Avidemux
By Ahari in forum Newbie / General discussionsReplies: 28Last Post: 18th Mar 2025, 14:22 -
avidemux cannot open mp4 files
By Narayan in forum LinuxReplies: 15Last Post: 28th Jun 2015, 08:47 -
crash on mkv file
By bzipitidoo in forum LinuxReplies: 5Last Post: 6th Aug 2014, 16:16 -
AVI file won't open after converting in Avidemux
By AaronAdkins in forum Video ConversionReplies: 7Last Post: 19th Aug 2012, 04:01 -
fcp.file in avidemux??
By rachelH in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2011, 16:46
