Aargh! I wish I had the money for a decent authoring tool like dostudio or scenarist and I could ditch this sorry excuse of an authoring tool.
It was a while ago and I can't remember what the problem was. But my workflows admittedly were a mess then. I will run some tests tonight to see if I get the same problems again.
Results 31 to 33 of 33
Just use720p and double the frame rate with ChangeFPS(). The exact duplicate frames will take hardly any additional bitrate compared to --pulldown double. Though x264 is frame rate aware and will use slightly higher average quantizers for the double frame rate video. You can make up for that by selecting a CRF value ~0.5 below your usual.
Well, I did a small test last night and sure enough Encore was able to handle the 1080 --fake interlace. But, Encore is super slow with it. I know I would experience serious problems with longer timelines. That is ok though. I have no qualms with encoding my 1080p content as 720p. I don't harbor any fantasies that my video has 1080 lines of resolution. Sometimes, ease of the workflow trumps everything else.
jagabo, thank you, that sounds like a good strategy. I naively assumed that --pulldown double did the same thing. My video encodes with ~85% 3 consecutive b-frames (the optimal number when I encode for the web is around 6 or 7), so duplicate frames as you said should not significantly increase the bit rate.
Cant encode this scene in x264 without blocking
By premiumcapture in forum Video ConversionReplies: 15Last Post: 29th Mar 2015, 10:13 -
How do I encode using Avisynth and x264
By Placebo in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2014, 21:26 -
How to encode anime to 10bit x264?
By Deadly9000 in forum Video ConversionReplies: 45Last Post: 12th Mar 2012, 09:10 -
How to encode using H x264 in Virtual dub
By cyberlion in forum EditingReplies: 21Last Post: 1st Sep 2011, 23:45 -
Can't get good quality x264 encode
By silverwolf0 in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2011, 21:45
