Hi guys,
Is the people at MP4tools still around ? Unfortunately they made it so the registration code only works with name of the computer and i had forgot about it and changed it after doing a clean installs of El Captain, sent them an e-mail requesting a new code but no answer.
Any suggestions?
Thanks.
Last activity: 1st Jun 2012. I think you're out of luck here.
General Registration InformationOriginally Posted by winterds
The applications use a very simplistic registration system. The original system was tied to individual computers, meaning applications would have to be registered for each computer it was used on, even if you were just upgrading your computer. As of version 3 for all applications, the registration code is based on the name of the original user account on your computer. This means that, assuming your account names are the same, your application will be transferable when you upgrade computers, or even if you have multiple computers. If you want to use the applications on computers that have a different user account name, then you will have to register again. That's not the best system in the world, [...] (emphasis mine)
Not sure if autocorrect can be blamed hereOriginally Posted by winterds
Ouch. I kinda doubt you will get an e-mail answer, as your action of choosing a new username is in conflict with the registration scheme that you agreed to. Unfortunate.Originally Posted by winterds
Rename the original user account on your computer. That isn't easy, on purpose. The last time I tried that was in 2008, Mac OS X 10.4 Tiger probably, using some 3rd party tool, which was risky anyway and which may no longer work with the current system. If all else fails, you may have to do another clean install of the OS, or choose to re-register the app.Originally Posted by winterds
MP4Tools H.265 (HEVC) support?
By Doc. Caliban in forum MacReplies: 1Last Post: 27th Jun 2015, 03:26 -
Join m4v splitted with mp4tools?
By Cartman in forum Video ConversionReplies: 2Last Post: 10th Jan 2012, 17:12 -
I have not received the registration code.
By oyak in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2011, 00:20 -
Registration Code Error
By ghillman100 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Apr 2011, 11:07 -
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum Capturing and VCRReplies: 4Last Post: 21st Nov 2010, 23:22
